E-Class (W211) 2003-2009
Will these rims work???
Old Oct 5, 2006 | 12:26 AM
99bmw740il's Avatar
2006 Mercedes E350 Sport
20" X 8.5" and 20" X 9.5" with a 5 X 120 bolt pattern. The offset is 35mm front and 40mm rear.
Old Oct 5, 2006 | 02:44 AM
kevinle's Avatar
yes they will fit your w211, but if the offset are 25 fronts and 32 rears they will look perfect
Old Oct 5, 2006 | 12:01 PM
denrique's Avatar
2010 x164
W211 uses 5 x 112 bolt pattern
The W211 uses a 5 x 112 bolt pattern. So 5 x 120 won't fit.
Old Oct 5, 2006 | 08:26 PM
99bmw740il's Avatar
so will it look retarded?
Old Oct 5, 2006 | 09:14 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
You might look retarded if you don't yourself check for the correct bolt pattern.
Old Oct 6, 2006 | 12:39 AM
99bmw740il's Avatar
id get adapters for the price of these
Old Oct 6, 2006 | 09:06 AM
ima55r2's Avatar
I haven't seen adaptors for bolt patterns but check out how to measure the pattern yourself.
http://www.rsracing.com/tech-wheel.html
