E-Class (W211) 2003-2009
Does These Wheels Fit e350?
Old Oct 20, 2006 | 11:53 AM
tphan619's Avatar
2006 e350
https://mbworld.org/forums/classifieds/164255-hre-447r-19x8-19x10-brushed-aluminum.html
I was wondering if these wheels that came off the clk will fit the w211 e350.
Old Oct 20, 2006 | 12:39 PM
2001CLK's Avatar
2001 CLK320, 2003 E320
Those will not fit on the 211's.. The CLK's have smaller diameter bolts. They sure do look nice tho..
Old Oct 20, 2006 | 12:41 PM
tphan619's Avatar
2006 e350
Originally Posted by 2001CLK
Someone correct me if I'm wrong but I'm pretty sure those will not fit on the 211's.. The CLK's have smaller diameter bolts.
These are coming off the w209 clk. So not sure if that makes a difference from the w208
Old Oct 20, 2006 | 01:04 PM
2001CLK's Avatar
The w208,w209 uses the 12x1.5 lug bolts and the W211 uses 14x1.5 lug bolts. Unless these are drilled wider to accept the 14mm bolts and the offses are correct then you shouldn't have a problem.. But being that they are HRE's I would guess they are made to spec so the holes will be too small to take the larger 14mm bolts from the E.
Old Oct 20, 2006 | 01:15 PM
tphan619's Avatar
2006 e350
I hope so. Can anyone confirm?
Old Oct 20, 2006 | 05:23 PM
jagata's Avatar
S6 LP640 E500
confirmed, clk has 12mm bolts not like the w211 14mm.
Old Oct 20, 2006 | 07:30 PM
tphan619's Avatar
2006 e350
So no way to have these HRE fit the w211?
Old Oct 20, 2006 | 07:52 PM
W211 Ryda's Avatar
2004 E320
Unless you drill the holes to accomodate 14mm bolts...but then you risk the chance of cracking the rims. Plus the offset may not be suitable for the W211.
Old Oct 23, 2006 | 10:03 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
https://mbworld.org/forums/showthread.php?t=164255
You have a PM.
