E-Class (W211) 2003-2009
Sirius Presets Question
Old Oct 29, 2006 | 12:04 AM
knbcpab's Avatar
I have a 2007 E350 with factory Sirius installed. Question I set the preset on the radio BUT now I can't scan through all the channels?. If I hit a preset it only goes up or down about 10 channels. If I start at preset 1 I cant get past 10. Also how do you delete presets?
Old Oct 29, 2006 | 09:14 AM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
I was reading your question and I don't seem to able to understand what your are asking. Can you provide a little more detail?
However the last question is easy. I don't delete the presets, you store a new channel on top of the one already set. If you want to clear them all you can reset everything back to factory defaults. That will take everything including and other changes you have made.
Old Oct 29, 2006 | 11:16 AM
aceman's Avatar
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
sirius presets...
When you press the up/down arrows on the steering wheel, you are scanning throught the sirius channels in the genre you're listening to. For example, if you're in the rock genre, youl'll scan through the 10-15 rock channels. Our 60K+ vehicle still does not have the ability to schan through memory presets - pretty pathetic IMO!!!
Aceman
