Steering noise after D service
DTB P-B-46.30/40 APR06 Flow Noises from Area of Power Steering Pump and/or Foaming of Power Steering Oil in Reservoir. Improper procedure followed for filling and bleeding of the power steering fluid into the system. It is necessary to turn the steering to full lock to lock at least 30 times before starting the engine. If this is not done prior to starting engine, there is a high risk of air entering the steering system. Starting the engine prior to bleeding can cause irreparable damage to the power steering pump and will cause an air cushion to form in the steering gear which causes noise.
