E-Class (W211) 2003-2009
Electrical Malfunction
Old Nov 23, 2006 | 04:20 AM
silver-55's Avatar
Malfunction electrical consumers switched off..
as topic...after start driving the car for 2 mins or so the following comes up on the dash.
The pano roof, passenger seat, parktronic and interior lights none of them are working.
I've changed the small battery in the front like a week ago.
Is there anyways I can reset this?
Any bro have the same issue before?
Thanks alot guys....
Old Nov 23, 2006 | 06:44 AM
SUNILP's Avatar
2015 E250D
The small battery in front is a starting battery. The consumers battery is in the rear.
Old Nov 24, 2006 | 10:25 PM
saintvir's Avatar
'23 EQE 350 4MATIC
Could be related to this bulletin: Wed, Jun 14, 2006 2005060008D Campaign - Reprogram Battery Control Module
Try this link: http://www.alldata.com/tsb/Mercedes-...dex-issue.html
Scroll down the page to find the link to the bulletin.
Old Nov 25, 2006 | 09:09 AM
SUNILP's Avatar
2015 E250D
Yes it could be and if your BCM was not programmed with new software, I would do that.
Old Nov 25, 2006 | 10:23 AM
BudC's Avatar
2011 E550, 2013 GLK
What's the model year of your car?
Old Nov 25, 2006 | 10:37 AM
silver-55's Avatar
It's a 2002 E240
Old Nov 25, 2006 | 10:50 AM
BudC's Avatar
2011 E550, 2013 GLK
Originally Posted by silver-55
It's a 2002 E240
Could any of these apply?
Service Campaign 2005070017 FEB06
Inspect alternator, replace regulator if necessary
E / SL (2002-2005)
Service Campaign 2005060008 JAN06
Programming battery control module
E (2003-2006) / CLS
Service Campaign 2005100009 NOV05
Inspect rear SAM control module, replace if necessary
E (2003)
I did have to have my battery replaced at about two years under the warranty. They told me that these batteries are not like the ones in the past in that they can test fine one day and go dead the next.
Old Nov 25, 2006 | 11:33 PM
211E350Black's Avatar
08 CLK350
front battery for your sbc not for starting
Old Nov 26, 2006 | 10:45 AM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
It's a 2002 E240
Your car is a W210 not a W211. You might bet better answers in the W210 forum. Also, I don't beleive that your car has SBC. It was introduced with the '03 MY.
Old Nov 26, 2006 | 08:34 PM
silver-55's Avatar
My car is indeed a W211. 02 is the first year of production of W211. not 03.
Anyways thanks everyone for the help.
Old Nov 26, 2006 | 11:11 PM
sgaar's Avatar
What you might have is a MY 2003 titled in mid/late 2002. Much like you can now buy a MY '07. The W211 did not get to market until the 2003 MY.
http://en.wikipedia.org/wiki/Mercedes-Benz_W211
http://www.edmunds.com/insideline/do...rticleId=10032
Old Nov 26, 2006 | 11:13 PM
Barry45RPM's Avatar
2015 ML 350
Didn't the 211 go on sale in Europe in early Spring '02?
Old Nov 29, 2006 | 05:01 PM
Clinton Horn's Avatar
2003 E320
Consumer Electrics Shutdown
My new to me 2003 E320 started this about a week ago. Never noticed it shutting down accessories but this problem may be a fault attributed to poor service. Since the car remains under warranty, I cannot envision some shade tree mechanic messing with it but prior to 90 days ago, I could not say
Diagnosis from dealer:
"Check for codes Found Codes in on-board Electrical Supply 9050 and 9051 Check actual value of batteries voltage- Found both 2AL3L-TO8PO C63L -H9APO batteries passed MID. test codes Perform Electrical test on charging Found ALT output at 145 amps and 12 volts but intermittently will fail to 75 amps at 11.6 volts. Check Electrical connections on alt. Found tight. Found electrical cable between rear fuse panel and systems battery loose and arcing, was necessary to clean and tighten cable. Charging system works fine after. "
This must have been on the fuse panel end because I had inspected the battery clamp previously and it was tight.
Probably a "one off" problem but it would be easy enough to check.
PS I have a mini van with 120 amp alternator and I thought that was a whopper. You could arc weld with the MB unit
Old Mar 29, 2008 | 02:41 PM
Double_M's Avatar
My friend have got a diesel
Hello,
My friend's 220CDI did have a poor (bad) alternator belt, there was "malfunction electrical consumers switched off" message at the dashboard, and some of these systems were shutdown
