E-Class (W211) 2003-2009
Resetting Throttle?
Old Dec 10, 2006 | 01:00 AM
spiritd's Avatar
Resetting Throttle?
*First Post*
Hey guys, I read somewhere that you can reset the throttle of your E Class giving you some better response? How do you do this?
I have a 2003 E320 RWD Sedan
Thanks!
Old Dec 10, 2006 | 12:51 PM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
Not quite sure what your source was referring to, but it may have been one of two things:
1. Keep the "W/S" button near the gearshift lever in "S". That allows the car to start in first gear instead of second; faster off the line at the expense of fuel economy. "W" is for snow or ice on the road.
2. The car supposedly adapts to your driving style, so for instance if you drive aggressively, the ECU (or whatever) will "learn" to shift at higher RPMs than if you feather-footed it.
Old Dec 10, 2006 | 04:57 PM
konigstiger's Avatar
'71 Pinto
If you mean reset the Engine Control Unit (ECU):
https://mbworld.org/forums/e-class-w211/148114-sneaky-ecu-reset-e55-forum.html
Old Dec 11, 2006 | 11:17 AM
ddskier's Avatar
'10 E550 4Matic, '09 S600, '07 CL600
*First Post*
Thanks!
The reseting is a pain in the butt. It only lasts about 3-4 days of normal driving, and then you have to do it again.
Get yourself a sprintbooster.
Old Dec 11, 2006 | 02:49 PM
starbrite's Avatar
2004 E320
Is 3 or 4 days really enough time for the ECU to "adapt" to your driving habits ?
