E-Class (W211) 2003-2009
Comand / Nav install guide
Old Dec 20, 2006 | 09:02 AM
jmorgis's Avatar
2013 SLK
Does anyone have instructions on how in install nav for you DIY ! Specifically dealing with the MOST fiber hookup (that some may have to do behind the b-pillar). Im starting this project and have read all the threads that I can find. but nothing that clearly covers the b-pillar connections under the door sill. There is a great thread already that covers the in trunk stuff.
Can anyone assist.?
John
Old Dec 20, 2006 | 08:36 PM
iookpareke's Avatar
Hmm i dont know abou the B-pillar. I never bothered with it. all the wires were already present in the trunk. And everthing worked fine!
Old Dec 21, 2006 | 04:09 AM
RoundZBenz's Avatar
E270 Avantgarde
I've just upgraded from the Audio 50 APS to the Comand and Nav drive and too had some trouble finding out how to wire everything up. There should be a spare optical connection in the trunk, next to the fuse box, which needs to go into the back of the nav drive. You should also find the electrical connectors there as well.
However, because it works on an optical ring, it is not the simple case of plug and play, because if there's nothing there today then it would mean a break in the optical ring and nothing would work...! In my case, and I believe most cars that were fitted with MOST and an AG (Audio Gateway) you will need to re-connect two optical wires that run along the rear left and door sill. If you take up the plastic tread and pull back the carpet, you should see a number of orange optical cables. Two of these should not be connected to anything at the moment and from memory they should be labled 14 and XX16. You need to break one of the other loops (again from memory these cables are labled 13 and 20). If you then re-connect the cables, 13 to 14 and XX16 to 20 (if I've got the numbers right) then the ring has now been extended to the spare optical connector in the boot (trunk) and everything will work....
If you have upgraded from Audio 50 APS then the controls on the dash and steering wheel should work straight away. If you've upgraded from Audio 20, then the above might not help you because I don't believe that these cars were fitted with Audio Gateways (AGs)?
Hope this helps, I have got some wiring diagrams somewhere if that helps I could dig them out.
James
Old Dec 21, 2006 | 10:08 AM
jmorgis's Avatar
2013 SLK
RoundZBenz, thanks very much. That is what I thought. I will take pics when I do this and post them here. Does anyone know how much MB will charge to program/reprogram the MOST loop to get instructions in the dash? Or is that not needed?
John
Old Dec 21, 2006 | 11:02 AM
RoundZBenz's Avatar
E270 Avantgarde
What are you upgrading from? Audio 20 / 50? If it's an audio 50 APS, did you have the sat nav? If the answer is yes to these two questions, then you do not need any further programming (which was the case in mine). Otherwise, hopefully someone else will be able to tell you how much it would be in the US. I believe it would need to be a MB Dealer, with Star Diag.
James
Old Dec 21, 2006 | 11:12 AM
jmorgis's Avatar
2013 SLK
I have the Audio 50 right now (small screen with tape deck), and going to US comand head unit. I dont have any nav, but i visually checked my truck, and my car looks to be pre-wired. (2003 E320) late build
John
Old Dec 21, 2006 | 11:22 AM
RoundZBenz's Avatar
E270 Avantgarde
I was lucky as mine came with Audio 50 with the Nav CD drive (integrated) and, therefore, no more programming to make it work on the dash / steering wheel. However, the fact that you have an Audio 50 you should be fine because, from what I know, everything was pre-wired, including the audio gateway (AG). If you didn't have this then I believe it's a real pain to retrofit.
Good luck and let me know how you got on.
James
Last edited by RoundZBenz; Dec 21, 2006 at 11:24 AM. Reason: Forgot to say something
Old Dec 22, 2006 | 08:21 AM
jmorgis's Avatar
2013 SLK
Ok, guys help me out with this one. I cant figure out why MB only charges $274 for the DVD Navigation Processor that mounts in the trunk. These things sell for 400-500 bucks used on ebay.
The part number is A211 820 06 85
Why can I get it cheaper band new from a MB dealer? Is it the wrong unit?
John
Old Dec 23, 2006 | 01:18 AM
skymast's Avatar
2013 G550
the MB price requires a core exchange. If you dont have one, it is + 300.
Old Oct 1, 2008 | 06:19 PM
007_e350's Avatar
X166 gls450 2017
I just called my mb dealer for the nav device that goes in the trunk & that *itch says;
Part # 211-870-1085
is for $6100
I told her its merely a 2 grand option ... and I didnt understand what bull*hit she said in reply.... *reakin ****** sittin in the mb parts dept
Old Oct 2, 2008 | 01:39 AM
Diesel Benz's Avatar
Part # 211-870-1085
is for $6100
Has something happened with the prices:
http://www.mercedes-benz-parts.co.uk...com_virtuemart
Still should not be $6100, specifically when the demand should be more on the NTG2.5 device.
Old Oct 2, 2008 | 01:42 AM
John
This should be an old part, the current one is A2118706085 I believe, not sure if there is any significant difference once the SW is updated.
Old Oct 3, 2008 | 04:30 PM
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
James
I just used this procedure to add the nav dvd to my euro comand but, when I push the nav button it says, "Nav activated... pls wait."
That's it!
Also when I take the disc out and put it back in it says insert nav dvd.
Do I need Star programing/new disc...help.
