E-Class (W211) 2003-2009
CDI Power Loss
Old Dec 24, 2006 | 03:18 AM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
CDI Power Loss
My wife complained that she had no power going up a hill.( 05 CDI, 38,000miles). I did the husband thing and asked her if she had pressed the pedal all the way to the floor. She kind of glared at me, ( she went to Skip Barber school with me!) and said she had. When I drove it yesterday, coming off a run of about 30 minutes at 75, it had no power. Pedal to floor, no passing gear, RPM's going down. After shutdown at the parking lot, it was normal again.
I am pretty sure it is the EGR valve. I will call the dealer after the holidays. Will post.
Old Dec 24, 2006 | 08:03 AM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
egr
for certain this is your problem. My CDI EGR died at about 22K miles
Expensive part charged to MB hope this one last.
Steve
Old Dec 24, 2006 | 08:05 AM
TPAbnz's Avatar
2017 E300W
It sounds like Limp Home Mode if loss of power. There are other posts where folks describe their symptoms, but I think that's it.
You'll know if you turn off the ignition and re-start and it's OK.
I belive it was the EGR when I had this happen.
Old Dec 24, 2006 | 11:21 AM
Fastbuck's Avatar
2019 Mercedes Benz S500L AMG Premium Plus
I had this problem intermitently from the day I picked up my car form the dealer. It was hard to diagnose as it only occured when the external temp was a degree or so above or below freezing. It eventually happened at a time where I could get it to the dealer in the error state. it turned out to be the ECU which controlled the angle of the vanes on the turbo.
GL
M
Old Dec 24, 2006 | 07:12 PM
KosherBenz's Avatar
Its big and Grey!
Time for the Kleemann Mod!
Old Dec 25, 2006 | 12:43 AM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Did you mean the turbo "vanes"?
Originally Posted by Fastbuck
I had this problem intermitently from the day I picked up my car form the dealer. It was hard to diagnose as it only occured when the external temp was a degree or so above or below freezing. It eventually happened at a time where I could get it to the dealer in the error state. it turned out to be the ECU which controlled the angle of the veins on the turbo.
GL
M
Whatever you meant you need a Kleemann tuning box right now!!!!!!!!!!!
Merry Christmas (Kleesmannmust) my friend!
Old Dec 25, 2006 | 12:46 AM
harkgar's Avatar
Happy Honniker Kosher!
Dig your CLS wheels man!
You did not say what color code your CDi is.
Old Dec 25, 2006 | 11:51 AM
gbahri's Avatar
2003 CLK320
I dunno if this is what you are talking about, but my car just stopped working recently. I pushed the gas and nothing. I pulled over turned the car off and turned it back on then it worked. Turned out to be the electronic module in the gas pedal. Coast 300 bucks total to fix.
Old Dec 25, 2006 | 04:18 PM
harkgar's Avatar
how much?
Steve
How much is the EGR if you have to pay for it? Normally EGRs are cheap, for gasoline engines anyway.
Old Dec 26, 2006 | 06:05 AM
KosherBenz's Avatar
Its big and Grey!
thank you sir!
color code is = Barolo Red Metallic (Mfr Code @E544)
Old Dec 28, 2006 | 10:29 AM
expat5's Avatar
Gray Market 04 E320 CDI import, Euro COMAND, & Hitch
For what it's worth, I had an 04 CDI with 2000km just turn off while driving in in a small village in Germany. Car would crank and try to start, but ultimately would not run. 3 days later the ECU was replaced,. I was told MB had some pretty serious QC problems with the ECUs before 04, but I dont know if this problem was contained to Europe or to CDIs in particular. I can tell you the problem has never recurred.
Old Dec 30, 2006 | 10:11 PM
rbordel's Avatar
05 E320 CDI
Originally Posted by jimbo1mcm
My wife complained that she had no power going up a hill.( 05 CDI, 38,000miles.)
I had the exact same thing happen on my 05 CDI at 24600 miles in July 2005. The problem was indeed the EGR sensor. It was replaced free of charge (the sensor, that is, not the car) and has not happened again The car currently has just over 42500 miles.
On the plus side, I got execellent fuel economy (40+ MPG on the highway) for the 1000 miles that I drove this way. The car in this condition was effectively a non-turbocharged CDI with restrictor plate installed.
