E-Class (W211) 2003-2009
'03 E320 right front turn signal
Old Jan 1, 2007 | 01:19 PM
bilcheek's Avatar
Question '03 E320 right front turn signal
I have an error indicator on my display telling me my right front turn signal is bad. I replaced the bulb per the owners manual but that did not fix the problem. Is there a flasher relay some place I can replace? Any info on this topic will be appreciated.
Old Jan 1, 2007 | 02:25 PM
csumt76's Avatar
LS7 powered Corvette
There is an updated turn signal socket with a new ground wire that you need to install. It takes a special tool to un-pin wire #1 in the headlight connector and a 10mm socket to removed the nut on the ground near the strut tower.
Old Jan 2, 2007 | 09:43 PM
saintvir's Avatar
'23 EQE 350 4MATIC
P-82-10-258C - Lighting - Front Turn Signals are Inoperative
csumt76 is correct. There is a bulleting on this item:
http://www.alldata.com/tsb/Mercedes-...dex-issue.html
Ctrl-F on "turn signal" ...
