NAV "Unlock" ??
Anyone seen this before?
It is worth the $12?
Click Here to View eBay Auction
). The rep in Stuttgart said all the drives are DVD. The 07 model NAV system is a DVD based Nav system. I am really curious to see what comes of this
1. Did you recieve last years command book with the old style steering wheel? I did.
2. Is the comand unit different than the 06 model and the changer? As posted above the rep at the factory told me every drive in the car is dvd player. Can someone verify this?
3. Is there an 07 command booklet that references the new steering wheel?
Don't waste your money, here's the trick how to get into engineering mode
Once there press and hold [#],[*], [left arrow] (in that order), until you see three italicised options on the right side of the COMAND.
I believe the first option controls DVD in Motion, the second, the region code, and the third, uh, I forget what the third does.
Hope that works for ya.
GL.
the Second option controls region code, check region free
Good luck messing with this but your US COMAND will not play DVD movies . . .if that's what you want, you need a European head unit.
Try a search of the multiple discussions on this.
but the tricks were given by a member in U.S
x-tian-230k is right, and as for jmorgis, you're right too. You see, the 2003 W211's with NAV are actually 2004 replacement cars badged as 2003's. These special replacement cars did have a DVD drive for the center slot in COMAND. Those lucky few who have the replacement cars can play DVD's. If you don't have one of these cars, you will need to purchase a Euro COMAND. No if's, and's or but's about it.
Luckily, these units can be had for about 700.00 on ebay.
