E-Class (W211) 2003-2009
The cold weather's effect on suspension - My First Post!
Old Jan 17, 2007 | 09:12 PM
IAHdriver's Avatar
E500
Hey all, long time lurker now a member.
Here's my problem:
I've noticed that when I start the car and drive in cold weather, the suspension makes a groaning noise as I go over bumps in the road. It continues for about 15 minutes. Not only does the car groan, it squeeks and generally feels like something is not right. I've had it checked, and the SM says there's nothing wrong with it.
My question is this: Is it normal?
I live in Houston, and rarely does it get this cold, so I've never experienced a problem. Should I take the car in?
Old Jan 18, 2007 | 12:51 AM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
Most cars make some type of suspension or tire noise when they're cold. Here in Chicago as of late (like between 5-15F) my CLK's tires and body protest the cold for a few minutes and then everything quiets down.
M
Old Jan 18, 2007 | 02:33 PM
georgedaman's Avatar
GL350
Mine does too..usually under -5C Its the shocks..atleast on mine..
Old Jan 18, 2007 | 11:21 PM
smb7420's Avatar
E500
I've got an 03 E500, it never makes groaning noises,
I live in Chicago(actual Chicago, not Chicagoland Suburbs), and it's lightly snowing.
You should hear noises similar to a rub/groan if you dont have a 4matic(maybe with 4matic also) and you're turning your tires left and right on ice(happens when i park in the garage)
Old Jan 22, 2007 | 01:11 PM
starbrite's Avatar
2004 E320
Tires !
A cold week here on Long Island and car wasn't driven for about 10 days ( parked in the garage).
Yesrterday, after driving about a mile, got on a parkway and as I approached 50mph starting getting
vibrations all around, like tires out of balance.
Slowed down to about 40 and was quite, so after another few miles starting getting back up to speed and then all was OK.
Must have been flat spots on the tires after sitting.
Old Jan 22, 2007 | 01:16 PM
MikeF's Avatar
03 C32 | 72 Porsche 914
The shocks do freeze in cold weather giving you not only a groaning noise but also a very rough ride. If you bounce the suspension a few times they usually free up.
-Mike
