E-Class (W211) 2003-2009
I give up.. front spring pad part #?
Old Jan 27, 2007 | 04:47 AM
W Cole's Avatar
makes your daughter horny
Ive been STFF for hours and still cant find it.
What is the part number for a front #1 spring pad?
Thanks,
W Cole
Old Jan 27, 2007 | 11:06 AM
tashakes's Avatar
2020 GLE350
For your 320, http://www.detali.ru/cat/oem_mb2.asp...SGR=052&SGN=01 There is no listing for the 350. Even with this info, call the parts dept at your nearest dealer to confirm. Hope this helps.
Cheers
Edward
Old Jan 27, 2007 | 05:41 PM
W Cole's Avatar
Hey thanks a bunch man. Yeah its for the 320 I forgot to mention that. Leaving the 350 bone stock for now..
Edit: In that diagram it looks Part #60 goes between the strut and the frame of the car. My E320 doesnt have this.. is that normal?
Old Jan 27, 2007 | 05:50 PM
john doe iii's Avatar
MY MB WAS LEMON'D
There are no spring pads for the front of the w211, only the rears. I found out the hard way. If you look above your springs where the pad "should" be, you will notice the smallest shim/pad that mercedes has.
Old Jan 27, 2007 | 06:53 PM
W Cole's Avatar
Are you sure about this? I think theres a lot of people on the forums who have changed their front spring pads. I just ordered a #1 front spring pad from my dealership. We'll see if it fits..
Edit: Another thing that is really confusing me is right now my car is raked. Lower in the FRONT than the rear. Which is the opposite of most people's problem. Im going to remove some of the plastic matierial in the rear (spring pad?). And hopefully go to a #1 pad in the front to lower it even more.
