E-Class (W211) 2003-2009
Help Bluetooth
Old Apr 21, 2007 | 09:23 AM
aliber90's Avatar
Red face Help Bluetooth
I have e 350 ( 2005) i have command APS with NAV with TV tuner,and cradle for Nokia 6100, but i found bluetooth key on my command. i used it to make a connection for my Nokia 7710 via bluetooth to command APS . the command found my moblie but after 2 Sec. disconnected and didn't pair. please help me how can i connet my 7710 to command APS via bluetooth that built in command. it need code?
Old Apr 21, 2007 | 10:52 AM
Diesel Benz's Avatar
You should be able to pair your 7710 with your Comand. You would need to enter the pairing code like for any BT connection, in this case you can decide on the code yourself as you would need to enter the same code on both devices.
However, the functionality is very limited, mainly exchange of visitor cards (see the electronics forum threads).
In order to be able to use BT telephony, you would need a BT puck (thousands of threads on different forums).
Are you from Europe? Based on your phone selection I would assume so. I also assume you have an UHI interface in your car, 6100 isn't supported by older kits. I believe 6100 does not support BT SAP, not sure about 7710 (other threads have a ling to a web page that lists all BT SAP capable phones). European BT pucks normally support BT SAP but there is now a BT HF profile puck available too.
