E-Class (W211) 2003-2009
Battery low message
Old May 7, 2007 | 03:20 PM
blke320's Avatar
05 E320
Battery low message
I keep getting this message in my message console
something like
"Battery power low, all conveniece features are temp unavailable"
then my speaker for the sounds system goes out and head light flickers...
sometimes, if i turn off the power to the sound, the speaker would come back temporarily...
Is it time for a new battery? my car is only 2 yr old! If i need a new battery, what kind of battery do you guys use? factory or aftermarket?
thanks!
Old May 7, 2007 | 03:44 PM
Barry45RPM's Avatar
2015 ML 350
There was a recall on the alternator & the battery control module.
Old May 7, 2007 | 04:02 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by blke320
I keep getting this message in my message console something like "Battery power low, all conveniece features are temp unavailable"
A trip to the dealer is advised. It may be either of the two batteries, battery connection, the battery control module (BCM), or worst case something causing a voltage drain – all covered by warranty. Service Campaign 2005060008 JUN06 – Programming battery control module and 2005070017 APR06 – Inspect alternator/regulator may apply. Also mention DTB P-B-54.21/155a JAN07 addressing BCM replacement. While in, have them check for any/all recalls and service campaigns applicable to your vehicle and update the Audio Gateway (AGW) and COMAND head unit software if not already performed.
Old May 7, 2007 | 07:45 PM
blke320's Avatar
05 E320
Thanks for all these great info! Going in the dealer tomorrow! I've had the headlight flicker for a long time... feels like the BCM issue??
Old May 24, 2007 | 03:26 PM
blke320's Avatar
05 E320
took the car to the dealer and they did a software update and and handed back my car with a smile. It only needed a software update he said. you are good to go!
I am all happy driving back to home and thought i enjoy my HK sound. I turn on the music and Aaa.... HK good!
As i get to the traffic light... OMG the speaker goes out again!
UNBELIEVABLE!!! I didn't get pass 3 mi from the dealer and there it goes again... as i drive toward home, the damn battery power low message appeares again...
I am speechless... these people at the dealer have no clue?!? are all MB dealer like this? they just don't give a damn.....
Old May 24, 2007 | 04:02 PM
willscam's Avatar
Black 2003 E320, 2001 BMW M Roadster
I had the exact same problem with my 03 E320; headlight flicker, sound going out, and getting the same message. It was the alternator. Tell them to replace it.
Old May 24, 2007 | 04:16 PM
blke320's Avatar
05 E320
sounds like this is not a new problem... yeah they just put in the second alternator... sigh....
I've taken the car in several time about the head light flickering.. and they tell me they don't see it flickering...
Thanks for the info willscam! i thought my eyes are going bad...
Old May 24, 2007 | 04:36 PM
'71 Pinto
The process to reprogram the BCM is straight forward navigating through STAR Diagnosis as is the alternator test. Since they ruled out both at this point (trusting their ability) it may be worth your while to request that they check for voltage drop to circumvent repeat visits. It involves disconnecting fuses and measuring the voltage drop directly at the fuse. Mention S-B-54.10/162 APR06. Or revisit their findings with the BCM and alternator!
If the problem is not resolved to your satisfaction this time around, I would suggest visiting another dealership.
Old May 24, 2007 | 07:35 PM
blke320's Avatar
05 E320
Thanks very much for the info konigstiger! I will keep it in mind.
I just hope they fix the problem for the last time...
