E-Class (W211) 2003-2009
Help! Brake issue..
Old May 9, 2007 | 10:42 PM
danpE320's Avatar
Help! Brake issue..
2003 E320 about 35k on it
I am getting a Brake Malfunction
says visit work shop.. this happened the day after I had Service B done and the factory warrenty is now up..
The brakes feel 100% fine, but when I start the car I get this... Any info anyone?
Old May 9, 2007 | 10:43 PM
Benz-O-Rama's Avatar
Had the same problem 2 weeks ago. Turned out to be a bad rear brake pad sensor, I think. Replaced under warranty.
Old May 9, 2007 | 10:45 PM
danpE320's Avatar
ok.. well it happened the DAY AFTER Factory warranty.. If I make a fuss will they just do it you think? Or could I just ignore the issue until I really need a brake job?
Brakes arn't covered under extended warranties?
Old May 10, 2007 | 12:30 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
>>>"ignore the issue "<<<
You have a brake warning, and in your mind you think "ignore the issue".
I can not think of a more irresponsible thing to do.
Old May 10, 2007 | 01:08 AM
victorylap's Avatar
2000 E320, 2007 Land Rover LR3 HSE, 2008 E350
Are you getting a Malfunction/Warning Msg BAS/ABS (visit workshop) - it's most likely a faulty brake light switch (very common problem)!
Old May 10, 2007 | 09:53 AM
danpE320's Avatar
no just says Brake visit work shop
Old May 10, 2007 | 10:13 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Dan,
As victorylap stated, it could be the light switch. You can also take the tires off and visually check all the brakes. Another thing would be to check the FSS and see if there's a "+" sign after the (new) service letter. If it appeared for B service, I'm sure the dealer would have told you since that would have been non-warranty money for them. On my 03 E320, the rear brakes worn down into the rotor and the sensor didn't trip because the sensored pad wasn't the one that worn first. The joys of floating calipers.........
Regards,
paul...
Old May 10, 2007 | 10:28 AM
OOH! OOH! That's what it was!
I would think if you're 1 day out of warranty, a very nicely toned call to your S.A. would do the trick. Bring him lunch when you take your car in...problem solved.
Old May 10, 2007 | 04:48 PM
danpE320's Avatar
so I brought it in.. I had to get new rear pads and senors in the back.. problems seems to be fine..
Old May 11, 2007 | 08:47 AM
paulv's Avatar
How did your front brakes look?
Regards,
paul...
Old May 12, 2007 | 11:00 PM
danpE320's Avatar
I was told my fronts looked good... So he changed the pads and senors but the Brake thing still comes up in my console. He told me he has to order some part that will fix the console free of charge which is good... I need to bring it back in monday
