E-Class (W211) 2003-2009
3rd brake light
Old May 19, 2007 | 10:52 PM
mechabenz's Avatar
e320 2003
3rd brake light
My trunk 3rd brake light is out, all cables are ok. Can someone post some tips on how to repair as no bulbs are involved and MB dealer says no coverage on extended plan.
Mechabenz 03 E 320
Old May 20, 2007 | 03:33 PM
211E350Black's Avatar
08 CLK350
buy a third brake light they are LEDs so you just cant replace one bulb you have to buy the whole assembly
Old May 21, 2007 | 01:28 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by mechabenz
My trunk 3rd brake light is out, all cables are ok. Can someone post some tips on how to repair as no bulbs are involved and MB dealer says no coverage on extended plan. Thanks Mechabenz 03 E 320
Possible solution...
Your problem may be related to the rear SAM (Signal Acquisition Module). If your 221.065 (E320) is within VIN range: A014562 – A159997 you can mention Service Campaign 2005100009 NOV05 Inspect rear SAM control module. The rear SAM is located behind the left trunk panel, if it is part # A002 545 99 01, A003 545 00 01, A211 545 19 01, or A211 545 20 01 replacement will be covered at no out of pocket cost.
In addition have them confirm that all Recall and Service Campaigns applicable to your vehicle have been performed.
Old May 24, 2007 | 02:47 PM
WMC's Avatar
WMC
97 E 420 w/ same third brake light prob
I have a 97 E 420 w/ 3rd brake light that I have not been able to get working either. Any ideas?? Have changed bulb twice.
