Staggered 19"s
What kind of pressure?
What is your normal load?
What are your driving habits?
All those come into play. Normally for that size its a performance tire, sticky, which won't get you much more than you got.
That sidewall number is MAX. Look at the sticker on your car for better values.
Yep, he's right. The pressure on the sidewall is max pressure. Running that much pressure must have made the ride super harsh. Was it? Also, is your car lowered?
The only thing you can do to help is rotate side to side. If you're running non-directional tires, than it's no problem. But if you run directional, as I do, you have the tires unmounted, then re-mounted on the other wheel. It'll help, but the fact of the matter is if you're gonna run staggered, directional tires, you're gonna have to live with replacing the tires frequently.
The camber kit for our cars doesn't do much. I was told by the alignment guy at my dealership to not even bother.
