E-Class (W211) 2003-2009
Locked keys in the car? (Keyless-Go)
Old 07-17-2007, 10:43 PM
  #51
Benz-O-Rama's Avatar
Originally Posted by amdeutsch
OK, lets expand on this.
Tonight I played with mine.
Starting conditions:
1) Car in garage unlocked.
2) Locked rear doors manually by opening them and pushing the button.
3) Got in on passenger side and manually locked driver's door from inside.
4) Opened passenger, left key in seat and manually locked door before getting out.
Result:
1) Went to trunk and was able to open it - this action did not unlock passenger compartment doors.
2) Pushed lock button on outside of trunk with no effect.
3) Car opened when using second key.
HTH
Take it away from here.
Interesting.
So, I guess it is possible but in my case the trunk was locked too. Friggin aliens!
Old 07-17-2007, 10:45 PM
  #52
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Originally Posted by Benz-O-Rama
Friggin aliens!
I take offense towards your negative reference of my avatar/sig pics.
(j/k)
Old 07-17-2007, 10:54 PM
  #53
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
You're partly right.
With the key in your pocket, briefcase etc, you can walk up to the locked car and pull the door handle. All 4 doors will unlock (or just the driver's if you configure it that way) and you can push a button on the gear selector to start the car. You push the same button to stop the car. You then get out, close the door, and push a small square button on the outside door handle, not on the key. You never ever need to even touch the key. Plus, it's just cool.
Now the remote starting would be bad-*** if MB offered it. The best MB can do is with the keyless go system you can walk up to the car and push the little unlock button on the outside pull handle while pushing a second button the inside of the pull handle. This will open all 4 windows and sunroof 1/2 way and start your ventilated seat, if so equipped.
I would think a good shop could install a remote starter too.
Your key locked in was a one time event that you can not recreate?
Sun spots, Solar flair
Old 07-18-2007, 05:25 AM
  #54
pinebaron's Avatar
07 E320 Bluetec
Originally Posted by Yacht Master
Why I ask, I guess I don't fully understand the keyless go system. Basically if you have the key in your pocket the doors unlock and you push a button to start the car. Then to lock it you push the button on the key. Right? Now I have seen the Chevrolet version and that remote starting is impressive and the range is over 150 yards. You can cool off your car before you leave your building. thats cool
You can either push the lock button on the key or push a button on any door handle to lock the car, so long as you have the key with you.
Old 07-18-2007, 10:08 AM
  #55
Actually,
I talked to a couple of places about doing a remote starter when I first got my car. Every one of them said it can't be done.
And yes, it seems to have been a fluke thing. I tried and tried to recreate it and couldn't.
Old 07-18-2007, 10:13 AM
  #56
cyclerider's Avatar
Harley-Davidson
. . . it seems to have been a fluke thing. I tried and tried to recreate it and couldn't.
The ONE unasked question in this long thread is this:
Is your wife a blonde?
Old 07-18-2007, 10:33 AM
  #57
Can't believe it took 56 posts for the question. Nope, quite brunette. And Caribbean to boot.
Old 07-18-2007, 10:37 AM
  #58
cyclerider's Avatar
Harley-Davidson
Dang - I thought I had finally solved the mystery!
Old 07-18-2007, 12:43 PM
  #59
AsianML's Avatar
2007 E63
Actually,
It's almost impossible on the ML with the switchblade key, much less the E with the SmartKey!!
Old 04-16-2015, 09:49 AM
  #60
Lava2ls2es's Avatar
ML400
Angry I just locked keys in car yesterday with keyless go!
Just last night I was picking my daughter up from a sporting event at her high school and opened the rear driver's side door, put my purse (with keys inside) on the back seat- this is common for me when I have a passenger since they changed the console, purse doesn't fit in front anymore
I grabbed the drivers door to get in & the car was locked. Keys inside- doors locked & would not open. Called the dealership, they made me call roadside assistance, the tech told me 30-45 mins to open the car & $120 fee (not included in roadside coverage). Was able to get a ride home from a neighbor & got the spare key & was back with my car open in 20 mins and cancelled service tech.
No idea how it locked or why it wouldn't open. Car has 2k miles on it 2015 ML400- Looked on line before calling the dealership back & saw this thread. Still cheesed off about this & that they wanted to charge $120 to undo a defect in keyless go!
Quick Reply: Locked keys in the car? (Keyless-Go)
