E-Class (W211) 2003-2009
SmartKey/Keyless Go question
Old Jul 19, 2007 | 05:29 PM
starbrite's Avatar
2004 E320
As always, thank you Barry !
Old Jul 20, 2007 | 12:27 AM
MissMyBenz's Avatar
'03 ML500, '07 E350 Sport (wife's)
Thanks for all the replies. Understand the balance and streamlining, just seems like having seat and mirror settings recognized by a key would not be too much to ask in a car of this price point. Even my XC90 by Ford, I mean Volvo did that. Does anyone know if it's a software only change that could be implemented? Was also hoping I'd be able to save menu settings such as daytime running lights, etc.
Old Jul 20, 2007 | 02:02 PM
starbrite's Avatar
2004 E320
Originally Posted by Barry45RPM
The adjustment you are talking about is how much you want the nav to fade out the audio source you are currently listening to. To make the nav voice louder, put in a destination & get going. When she tells you to do something, hit the repeat button & while she is talking, increase the volume either on the comand or wheel. All the NAV comands forever after will be at that new volume. The music source volume will remain at their old volume.
The music fade out is a different adjustment. If you are unable to distinguish between the music & Nav comand talking & singing at the same time, you would adjust it to make the music volume lower in addition to increasing the NAV directions. (That way you don't have to have the NAV chick scream at you.)
Tried it today Barry and it worked like a charm.
There must have been a Command vol adjustment in '03 because on the "fade" options screen there
is a Vol adjustment softkey box, but its"whited" out. ( that's the one the manual shows as being the way to do it)
Old Jul 22, 2007 | 09:53 AM
sammyshammy's Avatar
05 E500 Wagon
Yesterday I had some time to finally fiddle with some of the options on my new to me wagon. I have two smartkeys with the different colored tabs without the keyless go option. As stated above, in the manual it says in the key dependent section of the system to activate it on for each key being dependent. This is supposed to be under the convenience submenu. When I go to that submenu I cannot obtain the key-dependent feature. Am I doing something wrong or is this feature not available on my model. This is a 05 E500 wagon. Thanks
