Raining in Vegas
Odd if it wipes along with the spray function (it should but why does it not with the normal settings).
Yous should envy my place, can test vipers more frequently
EXCEPT ... that after 1,000 miles they are now doing a
“jitter bug jump” as they go back and forth when there
is just a sprinkle.
The wipers are “probably” old and dry, even tho it’s an
08.
jimm
‘08 E350 Sport, P2, Black/black,Parktronic,
Voice, Bluetooth, Burl Walnut, Split rear seat,
Wood/leather steering wheel
is just a sprinkle.
08.
jimm
Yup - my '07 E550 did that too. Both wipers would shudder in light rain. My wipers were out of also alignment - where the driver's side wiper would touch the other wiper, on the downward sweep.
Dealership adjusted the wiper alignment and then changed my wiper blades. Much better now. They also recommended that I get some 'diamond coating process' (I think that's what it's called) done on my windshield. Anyone try that?
I agree it's odd that the wipers will only swipe when using the washer function. I suspect it's a problem with the control arm. I like to tinker, so I think I'll disassemble the arm and take a look. I guess nobody else has had the same experience.
It was raining here in NY and i had my wipers set on intermit and it stopped working after 5 minutes. I tried turning it to I and II but still nothing. So i turned the car around back home and it started to work again. I then think it may just be a comp issue, so i drive back to work agian...then it stops working again! I turn to I and it works (Thank God!) but it stops for about a minute (three times in my 35 minute comute) and it goes agian. But just like Willscam said, when i use the push the stalk to spray, it works.
I think it may be something to do with the stalk or wiper motor. I also have a old problem when i make a left turn signal with the wipers on, the wipers stop until i complete the turn. Anyone else have issues like this?
I assume the issue is with the stalk, I've see quite a few posts about that, actually my W211 has acted shortly a couple of times.
The stalk switch info is delivered through CAN bus, if the wiper motor works in one case (like when pushing the stalk for spraying), the motor should be fine.
Some have had help from cleaning the stalk with compressed air and possibly with some appropriate cleaning spray, like the stuff used for potentiometers.
http://www.detali.ru/cat/oem_mb2.asp...SGR=120&SGN=05
Instructions (sorry no pics)
Tools needed:
10 mm socket (to remove battery -negative cable)
#2 Philips & Flat screw driver
T27 torx bit - get the folding set (which has a couple other sizes in it, $5 in Sears)
10 mm HEX socket (to picture it - the male version of the regular socket)
Remove steering wheel as detailed in previous thread:
https://mbworld.org/forums/e-class-w211/159220-wood-steering-wheel-upgrade-steps.html
(Make sure you read all the way through as there are better tips on removal later on.)
1)After you remove the steering wheel, there is a plastic plate/wheel which controls the SRS. You can notice the screwholes on the outer edge of the plate/wheel. Spin the plate around and line up the holes to the screws behind it for removal, one by one (there should be 3). Then, just use the flat head to kind of pry it out GENTLY(BECAREFUL - its plastic and the right side is where the electrical connetor is).
2) Underneath the steering column, there is another torx screw you need to remove (its the same as the one you see in the new part - its the tightening clamp contraction).
3) Remove the Cruise Control, SRS, steering wheel adjsuter and heated steering wheel switch (if equipped). These should just come right out.
4) You sould notice a phillips screw on the bottom which you need to remove.
5) Pry open the two thick aluminum clips holding the turn signal switch in place on the top left and lower right. (see new part for reference). I used a thin medium length driver which worked well. As you pry open and pull toward yourself, BECAREFUL as once you get it out, you could hit yourself in the face. The steering column cover and the switch comes out together.
6) Remove three philips screws from steering colum cover to detach from the signal switch. REMOVAL DONE!
7) Installation is reverse of removal, BUT pry apart the two thick alumimun clips on the new part before starting installation to make it easier to slide in.
Things to consider:
a) I removed my negative cable in both the front and rear battery. You probably dont have to remove it as many members have NOT removed the cable and had success. I got an SRS malfunction either way.
b) To remove the steering wheel, turn it 90 degrees before you start working on anything. It's easier to get to the torx screws out that are holding the airbag to the wheel. Remember to adjust the steering way all the way out too. There is also a metal structure plate attached inside steering wheel after you remove the airbag. Be sure to remove that as well becuase there are more electrical connectors behind that.
c) When prying apart the thick clips on the new part, becareful not to break anything.
THE REASON WHY IT BROKE:
I think this may be the case for everyone who had this problem. If you look to the wires on the old switch (red, yellow, and blue) toward the bottom of the stalk, observe the condition of the wiring. I touched the blue wire and it crumbled apart. I think the wire may have been overloaded and caused it to weaken not haveing enough electrical current to pass to the control mechanism --> therefore not working or sparatically working.
Concern: wipers don't work
Cause: bad contacts
Correction: replace combi switch
Parts: spo 000 545 22 10 - $75
Shop supplies - $22.64
Labor - $226.44
Total with tax - $ 331.65
I ended up having to pay $100.84 out of pocket and the warranty paid $230.81.
Tools needed:
https://mbworld.org/forums/showthread.php?t=159220
Things to consider:
https://mbworld.org/forums/showthrea...highlight=wood
