E-Class (W211) 2003-2009
Sunroof Problem
Old Aug 24, 2007 | 09:26 AM
GeorgeThompson's Avatar
Silver 2004 E500 4Matic
Sunroof Problem
Hey Guys,
Having an issue with the sunroof. If I try to open it, it only slides back about 1 inch. I have to keep tapping the button for it to go back all the way. Once it is open it will close with no problem. I also tried to hold the button to open it, but that doesn't work either. Anyone have a suggestion?
Old Aug 24, 2007 | 01:29 PM
Clinton Horn's Avatar
2003 E320
It sounds like a programming problem. When the battery is disconnected or dead, it requires reprogramming some functions in the car. I think you hold the sunroof switch open or closed for 5 seconds or something like that. Someone will chime in with the exact procedure. I have a Japanese car and it does the same thing. Must be something that the universal sunroof motor association cooked up.
Old Aug 24, 2007 | 01:51 PM
j_belll's Avatar
‘23 EQS AMG
take to dealer. its all under warranty.
Old Aug 24, 2007 | 01:52 PM
rodwilk's Avatar
98 CLK 320 03 ML500 04 SL 500
My CLK does the same thing. I got out of the car, locked it and held the remote button down for about 5 to 10 seconds. Actually I did it twice and it began to work fine again.
Old Aug 24, 2007 | 02:07 PM
Fastbuck's Avatar
2019 Mercedes Benz S500L AMG Premium Plus
Definitely sounds if you need to calibrate the roof as per instructions in the manual.
