E-Class (W211) 2003-2009
Clear side marker for 07 E class?
Old Apr 16, 2008 | 02:47 PM
bertman's Avatar
08 E350 Sport 65 Plymouth Satellite Jeep GC Porsche 944
A couple of quick pic's of the clear corners with the amber bulbs on the '08. The amber bulb doesn't showup as much as I expected. Stealth bulbs are on order from XenonMods.
Old Apr 17, 2008 | 01:12 PM
ucsdsig's Avatar
'08 E63, '08 ML350
Looks nice. How did you install the markers? Did you do it yourself?
Old Apr 17, 2008 | 03:45 PM
bertman's Avatar
It's a simple install. I removed the plastic belly pan at the front bumper (8 hex screws) to get full access to each side. The lens snaps in/out at the rear; it's a little tough to get the clips to release so I ended up using pliars to compress the clips.
It's a subtle change but I think it cleans up the look of the front.
Old Apr 17, 2008 | 05:23 PM
Tymah123's Avatar
2011 BMW X5 SAV
How's the quality of those aftermarket clear markers? Does the construction look sloppy? Do they feel any different from the OEM ones?
Old Apr 17, 2008 | 08:30 PM
bertman's Avatar
I'm happy with the quality. The fit is just like the OE lens.
Old Apr 17, 2008 | 09:07 PM
j_belll's Avatar
‘23 EQS AMG
Originally Posted by Tom F.
Why would you want to paint them? And what color?
gives it a cleaner look. body color.
Old Apr 17, 2008 | 10:34 PM
  #32
pinebaron's Avatar
07 E320 Bluetec
I just ordered too; I am looking forward to the clean look.
Old Apr 17, 2008 | 11:55 PM
  #33
mpx220's Avatar
2006 Mercedes Benz E350
+1. Makes it look more like the euro bumper which has no side markers. And the orange just doesn't look good as well...
Old Apr 18, 2008 | 08:58 PM
  #34
Piranajoe's Avatar
2003 E500
Here a few pics of my clear markers, I changed the bulbs to blue.
Old Apr 22, 2008 | 12:50 PM
  #35
mprsev's Avatar
2024 G63, 2021 X7M50i
I too dropped the lower front plastic pan but could barely get my arm up the front bumper to reach the light and even after I could squeeze the two prongs toward the back of the light the light would not come out. Am I missing something?
Old Apr 22, 2008 | 01:10 PM
  #36
Piranajoe's Avatar
2003 E500
It's very tight and hard to get a good grip, I used some needle nose to squeeze it , it eventually snapped out.
Old Apr 22, 2008 | 01:36 PM
  #37
bertman's Avatar
I agree they're tight. I was afraid of breaking the clips but a strong squeeze with pliars and they eventually released. The clips are stronger than you might think, so really "bear down" and they will come loose.
Old Apr 22, 2008 | 02:56 PM
  #38
unclebenz's Avatar
Anybody here want to sell me there orange OEM corner lens for the 2008 E class. PM me thanks.
Old Apr 22, 2008 | 03:57 PM
  #39
mprsev's Avatar
My issue is that there is not enough room to get my hand with pliers onto the clips? The only other option is I will try to remove the front portion of my front fender well to see if I can access the light from the back rather then underneath.
Old Apr 22, 2008 | 09:08 PM
  #40
E3504matic's Avatar
2007 E350 4matic
I just got done doing mine. It was a pain to get the clip behind the marker so they would come out. I used a smaller flat head screw driver to help squeeze the clips and push the marker out.
Getting to the back of the markers was pretty easy. I just turned the wheels inward on the side you are working on and popped the two clips out of the wheel well. You can then pull open the wheel well and access the rear of the marker.
Pay no attention to my unwashed car.
The bottom clip is underneath.
Here's another picture of the clear markers.
Old Apr 22, 2008 | 10:59 PM
  #41
pinebaron's Avatar
07 E320 Bluetec
Thanks for the pictures; I will be doing mine this weekend.
[QUOTE=E3504matic;2782122]I just got done doing mine. It was a pain to get the clip behind the marker so they would come out. I used a smaller flat head screw driver to help squeeze the clips and push the marker out.
Old Apr 23, 2008 | 03:10 PM
  #42
ucsdsig's Avatar
'08 E63, '08 ML350
Nice. Thanks for the pics
Old Apr 24, 2008 | 10:36 PM
  #43
mprsev's Avatar
The pics got it done!
Old Apr 25, 2008 | 01:11 PM
  #44
ucsdsig's Avatar
'08 E63, '08 ML350
Looks nice Hoping to get mine done this weekend.
How did you remove the clips from the wheel well? Do they just pull out?
Old Apr 25, 2008 | 02:09 PM
  #45
E3504matic's Avatar
2007 E350 4matic
They pull right out. The clips are a two piece deal. You have to pull the center core out first, then the clip will be able to compress and come out.
Old Apr 26, 2008 | 01:46 PM
  #46
pinebaron's Avatar
07 E320 Bluetec
New Pictures
A took a few closeups. Really look nice and worth it.
Attached Thumbnails Clear side marker for 07 E class?-p1010699.jpg   Clear side marker for 07 E class?-p1010700.jpg   Clear side marker for 07 E class?-p1010701.jpg
Old Apr 26, 2008 | 06:04 PM
  #47
bertman's Avatar
I agree... should have been done that way from factory. I swapped the amber bulbs for silver bulbs and it does remove the "egg yolk" look.
Old Apr 28, 2008 | 08:07 PM
  #48
pinebaron's Avatar
07 E320 Bluetec
I could not quite figure out exactly which ones are silver from Hoen; do you have the part/model # from Hoen?
Old Apr 28, 2008 | 11:22 PM
  #49
bertman's Avatar
I don't think the bulbs I bought are Hoen's. Mine are from http://www.xenonmods.com. $12.99 plus $1.00 shipping.
Old Apr 29, 2008 | 10:52 PM
  #50
pinebaron's Avatar
07 E320 Bluetec
My mistake. I see two models 194/168 & 906/921 (dual filament). I presume you got the 194/168. Please confirm.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
