US COMAND mp3 playback
S213 2020 E450 4Matic CDN Spec 07/19 build
Pretty darn sure that a minimum 128 bit-rate is required. (I had an e-copy of the COMAND manual but toasted it so can't quote chapter and verse.) Not sure what happened to the link to the other post was elsewhere in this thread, but it warned against too much compression (i.e. too low a bit rate). 320 bit-rate is the "least compressed", closest (in theory) to "CD quality".
"Permissable bit and scan rates: Fixed and variable bit rates up to 320 kbps."
Further on, it also says: "It is recommended to use mp3 tracks with a bit rate of 128 kbps or higher... lower rates may impair quality."
2006 C55 AMG, 2.8L Quattro, Softail Nostalgia 1550 (Stage III), Sporster (slammed)
It does display the whole filename across multiple lines if it's long instead of truncating it like on the main display. But that's about all.
My 04 e320 wont play in the cdc, but when i put it in the head unit it takes about a min to load and then my command sais MP3 and the cd plays and on the instrument cluster it sais MP3 and i can change it from the wheel. And when i click the audio button on the h/u it sais
cdc radio mp3 and aux. Im so happy
Thats how my Single Slot works & looks like. Its good to have all those tunes on one disk. Does your screen display the CD Name & Track Title as it plays each song?
yep , but i noticed i duno if its my cd but i made a mp3 cd with 95 tracks and half of the songs skip and dont play its weird i tryed it in my 07 shelby mustang with the mp3 radio and it does the same thing i duno it keeps skippin and wont play
#32
Gus...see above post re bitrate. Record at greater than 128 kbps and less than 320 kbps. I also SLOW down the recording speed to 16X. I find that sometimes makes a difference even on regular CD's.
#33
2000 E320 Won't Play Burned CD's on High-Quality MAM
Hello - new here! I can't believe it, but I invested good money into really high quality MAM audio CDR's and my cd player won't play the burned cd's. It has no problem playing burned cd's on cheap Sony CDR's. Can anyone help? I tried calling and emailing MAM and they couldn't offer any suggestions.
Thank you in advance!
#35
Hi, thanks for replying! After some research, I tried recording it at the lowest speed available on the cd burner I usually use - 10X 1500 kB/s. I have Windows Media Player too and I think it might have lower speeds. I've tried different formats too, like mp3, wma, etc.
#36
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
If you have a 2000 model, the manufacturer of the changer was Alpine. Alpine, back in 2000 (at least the head units) did not play CD-R discs all that well. Not sure why one brand would work and another would not, but if you find one that is working, I would stick with it. They have different dyes and the laser may read one variant better than another. If the laser reads the Sony, you should get the same sound quality as the other discs. A 0 and 1 is a 0 and 1.
#37
They deteriorate so quickly, even if just in the stereo, it was worth paying the extra for the MAM cd's.
#38
#39
#41
#42
I have an '04 E500 and I updated the Command Software myself from a file I downloaded off the internet (MERCEDES COMAND W211 SERVICE UPDATE - Nov 16 2006 ver 46.06). After this update I can play both CD-R MP3's and DVD-R MP3's only in the head unit and not the CDC. It also displays folders and song info on the display and instrument cluster. Using the DVD media is fantastic - you can load a ton of songs and organize them in folders. From what I have read this works on 03 and 04 models - can't say for the rest.
#43
can you play dvd movies?
hubi
#45
Only very very early US COMAND units will play DVD movies if you change the variant coding of the unit. They usually have the pictograms (like the Euro COMAND) on the bottom row instead of RPT/MUTE/EJECT/SEND/END text, and still have the SAT button.
#46
I changed it a while ago and was able to play DVDs but then I upgraded...downgraded and now I can go to EM and even hidden menu, plus the coding menu but in coding menu the system can't be changed to Euro...just 5 us versions....
#47
where did you get this file , could you email it to me or send me a link. I have an E55 04 model. I am having the same issues with Mp3s , I didnt use Itunes but will next time. can you check to see which version is on your command unit. I will check an see if I have the latest
#48
I can emial it to you - it is a small file and I got it from a torrent engine...it works for my 2004 E500 perfectly...just make sure to finalize the cd using Nero or other cd burning software. I am new to this forum and I am not sure how I would go about getting your email...
#49
Thanks , it worked like a charm and now my head unit will play MP3s and it puts it up on my speedo as well. very nice. I wish I could put my Iphone/ipod info on screen. I have the aux in the glove box and will be routing this down to my armrest but still nice to be able to show it on screen. if any one else needs the update let me know.
It is date ver Nov 2006
#50
only a few folders showing
hi
my comand is playing mp3s but not all of them...
for example I burned 7 folders last night on the cd (closed) and put into a comand - only 3 of them were visible.....
do you guys know why is that? do I need to use some special program like nero.....I burned via WIN and the 2nd disc using cdburned, both discs were finalized....
thanks
hubi
thanks
hubi
