E-Class (W211) 2003-2009
euro command not working
Old Sep 15, 2007 | 12:26 PM
dacollector's Avatar
13 E350 , 12 BMW 328i
i was listening music from my ipod, parked car, armed car. went in store, came back out, all but 5 minutes, start car , and there was no sound and or no screen. press the power button and the mercedes logo comes on, but that's it.
any info on a fix?
Old Sep 15, 2007 | 01:00 PM
MB500's Avatar
2021 Tesla M3SR+, 2017 GLS550, 2011 E350 Bluetec, 2007 GL450 (GONE), 2003 E500 (GONE)
any info on a fix?
sounds like a break in the MOST ring. Do you have access to another COMAND/Audio 50 unit? I would start with replacing the COMAND and see if the problem persists. If you see same problem with a different unit then there may be a break in the fiber optics line. You'd need to trace all of the components on the MOST ring and try to locate broken line. Count for at least three four hours to do the work.
If you don't have access to a different COMAND unit, I would take the car to the dealer and ask them read fault codes from AGW with STAR Diagnose tool. This is where audio-related errors stored. They should be able to give you a good idea of what is going on.
Old Sep 17, 2007 | 07:48 AM
Miguk_Saram's Avatar
'07 GL450
uh.. or you could try pulling FUSE #6, let the car rest for a minute or so, then put the fuse back in.
GL.
Old Sep 17, 2007 | 01:46 PM
thanks for all your reply's and help. i tried all, except take the whole car apart, i did the fuse thing, as well as install my old command , with the same result. i will take it to the dealer and see what they can find. i also noticed that the cd changer wont open as well.
Old Sep 17, 2007 | 03:00 PM
konigstiger's Avatar
'71 Pinto
MBUSA issued a DTB that addresses every malfunction you stated and it recommends the COMAND head unit software upgrade discussed here https://mbworld.org/forums/e-class-w211/200213-current-comand-sw.html However you have a Euro COMAND therefore I suggest using the European version disc W211 589 13 22 00.
Old Sep 17, 2007 | 06:51 PM
MB500's Avatar
Here is your problem! If your CD changer is not functioning there has to be a break in line between COMAND and CD changer. First time I did a retrofit on a COMAND unit and tried to power up without hooking up CD Changer, all I got was the MB logo. The unit acted as if it was dead. The second I plugged CD Changer in, everything worked fine. Check the connector between your COMAND and CD changer -- I bet this is your nemesis.
Alex
Old Sep 17, 2007 | 07:38 PM
thanks for the input, as i removed the euro command to reinstall my old usa command, i did take note of the three connectors just behind the ashtray, i also double checked to make sure all connections are tight prior to reinstalling back the euro command . pull the fuses again , hoping , and it still dosn't work. ohh well, i guess i'm in the hands of the dealer.
Old Sep 17, 2007 | 09:38 PM
tashakes's Avatar
2020 GLE350
Try unplugging your CD changer for 5 minutes and then plugging it back in, my changer is bad and if I use it, it will cause the same issues you are experiencing.
Since I have a Euro Comand, I really dont care about the changer, so I just dont use it anymore. The last time it happened, I just unplugged it for a few minutes, and when I plugged it back in, all was good. It has been working for at least a couple of months with no issues.
Hope it works.
Old Sep 17, 2007 | 10:14 PM
had every intention to drive home once again musicless, and to my suprise, everything work. the euro command play'd my ipod, dvd works, cd changer works fine. ... what the hell is going on?
all i did was turn on the key like usual and bam everything works. it didn't however played the music where it left off on the ipod , but it dosn't matter since it now works???.
thanks all that have tried to help me with idea's.
the power of the forums....
Old Sep 18, 2007 | 07:47 AM
'07 GL450
It was our collective mojo.
Glad it works!
