What is the story on changing Transmission Fluid?
My 2003 E500 is getting close to the 60,000 mile (100,000km) mark on its odometer. I’ve looked though my car’s service booklet but couldn’t find any mention of needing transmission fluid change at any point in time. Also, I remember reading on this forum that w211 transmissions are filled with a “lifetime’ fluid that should not be changed. However, many people on this forum claim that the transmission fluid should be changed at 40,000 miles (or 60,000 km). Could anyone educate me on where this information is coming from? This is not the question whether I should spend the money on changing the fluid but rather if the change is truly needed.
Thank you,
Alex
Thank you,
Alex
Received 4,435 Likes
'71 Pinto
Check item 20. Current requirements recommend an ATF & filter change every 39000 miles: https://mbworld.org/forums/showpost....1&postcount=45
2011 E550, 2013 GLK
Mercedes now recommend that the transmission fluid be changed at the first 40,000 kilometers (25K miles) to clean out the debris and then every 60,000 kilometers after that.
Mercedes recommend a new transmission fluid for the 7 speed transmission (ATF3353 (AO019894503)) and continue to recommend the same fluid for the 5 speed transmission FUCHS ATF 28 (A0019894603).
If you have 60K on your transmission, you should have it serviced.
