Jerking back and fourth at 30mph??
Whats the problem?
05" 320 CDI
Could it be the Idle speed regulator or RMP sensor? If there is something like that on these cars. Also this does not happen very ofter, 90% of the time everything is perfect.
Originally Posted by BLACKCDI
Don't know if it's a tranny problem, the jerking is consistant with RPM surging.
DTB specifically states “vehicle jolt at constant speeds or during gentle acceleration when torque converter clutch is applied > 40,000 miles”. Glycol contamination creates noticeable harsh engagement during gentle acceleration between 1200-2500 rpm, your call.
I am having the same problems, should this be covered under warranty? It has taken me around 10 trips to the MB Agent, and the chief engineer thinks it might be the clutch on my E240 W211, but cant say for sure, as he didnt really find anything wrong.
Would appreciate the help. Thanks
thanks
The MB dealer should have easily identified any fault codes including the MAF sensor through DAS. Did the independent find and printout any fault codes? If so, if you paid a diagnostic fee to the MB dealer return with a copy of the fault codes and request a discounted repair to cover their initial diagnostic cost, the diagnostic cost of the independent, and better the independent quote for repair because of the error.
Any help would be great, thanks.
So I attribute my problem to old tranny fluid (about 90k). Now the car is smooth as silk.
Thank you for the reply. Interesting outcome. I will set up an appt. to do just that. My car is out of warranty so I would much rather try the tranny change, as it has to be done some time anyway, than the EGR swap and software reflash. I have been quoted about $400.00 for the EGR and software. Did you do the tranny flush yourself? Anyone else have experience with the tranny oil change and filter change? Is it difficult and how much cost is involved.
What is the original recommended tranny oil change interval? Mine has 75K on it and it hasn't been changed yet that I know of.
Thanks in advance.
The above link is from an earlier model, but the only differences are that the W211 with the 722.6 5-speed AT does not have the drain for the torque converter, and our fill pipe is not as easily accessible requiring a funnel with a flexible pipe to refill the fluid.
