E-Class (W211) 2003-2009
Can overtightening your lug bolts warp your rotors?
Old 10-09-2007, 08:22 PM
Benz-O-Rama's Avatar
Here's why I ask:
I purchased the car with 29K on the clock and original pads and rotors. At 40K miles, I replaced all 4 corners with a slotted/drilled rotor from a company called irotors.com. These things warped after 5 thousand miles, which I thought was insane. I wrote a big rant on this board about them and purchased OEM spec rotors. I didn't get these rotors from a MB dealer but rather a website that stated they were OEM spec replacements. They came in a "Made in Germany" box so I felt ok with them. These felt great, as new rotors should But here we are, another 5 thousand miles later and these are warped too! I have 3 theories:
1. Both sets of replacement rotors were cheaply made and warped quickly due to lack of quality.
2. My calipers are sticking to some point, therefore overheating the rotors and causing them to warp. This is a reach, as my wheels and hubs would be burning hot after normal driving and that's just not the case.
3. In each case, the dealer replaced my rotors. And both times afterwards, when I went to swap out my wheels for my OEM winter wheels, I was unable to even break loose any of the lug bolts. Guys, you should see this. I've got the lug wrench on the bolt and I'm standing on the end of it and forcing all my weight down on it and the damn things just won't loosen. I tried 5 or 6 random lugs on 2 wheels, all with the same result.
So, could this be the cause of my problem? They're most likely using an air gun to tighten the bolts and not a torque wrench.
What do you think?, possible?
Old 10-09-2007, 08:50 PM
csumt76's Avatar
LS7 powered Corvette
Possible... Personally I have not seen it on OE rotors. Most of those impact guns are adjustable and they will reach or be just below the tq spec on the lo setting.
Do you have aftermarket lug bolts with those wheels? Are they chrome? These are much lower grade than the factory bolts and I have seen them shear off when over torqued.
What is the car doing exactly that leads you to warped rotors?
Old 10-09-2007, 09:01 PM
pinebaron's Avatar
07 E320 Bluetec
Originally Posted by Benz-O-Rama
Here's why I ask:
Absolutely! Always, Always, Always insist on using a torque wrench. Better still, purchase the best torque wrench you can afford; it is worth it. If you let a workshop tighten your lug nuts, the first thing you should do is verify the torque with your own torque wrench when you get home. I never let any workshop rotate tires on my cars, not even my Benz.
There are several other reasons for warping rotors. New rotors should sit perfect on the hub. Corrosion between the brake rotor and the hub, hub with excessive runout, worn or improperly adjusted wheel bearings or any damage or wear will lead to warped rotors.
Probably not very common, but never spray cool water on a hot rotor.
Old 10-09-2007, 09:13 PM
Yep, aftermarket chrome lug bolts. They seem to be holding the torque fine with no stripping. These are actually high end replacement bolts. The OEM wheels have a ball-seat bolt while my wheels require a tapered bolt.
Well, while braking the car shakes. I don't feel the pulsing in the pedal due to the SBC system. But we've all felt what warped rotors feel like, and this feels like that. Plus, every time I put new rotors on, the car stops smoothly. It's the rotors for sure.
Old 10-09-2007, 09:15 PM
Yeah, I'm gonna pick up a torque wrench and impact gun tomorrow. I'll need the gun to get these bolts off then I'll use the wrench to torque down the bolts on my OEM winter wheels. Then I'll need the dealer to replace the rotors and pads again and I'll have to re-torque them again, most likely. **Sigh**
Old 10-09-2007, 09:22 PM
pinebaron's Avatar
07 E320 Bluetec
Please ask the dealer to check other things I mentioned in my post; hub corrosion etc. I would hate to see it happen to you again.
Oh Yes, I never use an impact spanner on my lug nuts either; just use a long arm torque wrench that also helps loosen them up.
Old 10-09-2007, 09:27 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Gain weight prior to standing on the end of the torque wrench. (j/k)
Seriously now;
I've had that issue with my old C. I had a 2' long moment arm on the torque wrench and had to push down several times to break free the lug bolts on OEM wheels. If you have a breakerbar that'll slip over the end of your torque wrench and is fairly long I'd try that prior to an impact gun. Those guns, if used incorrectly, play havoc with regular sockets as well.
Old 10-09-2007, 09:38 PM
Seriously know;
I was thinking the same thing. I mean, I'm only 160 lbs soaking wet but I'm freakishly strong.
Was looking for a breaker bar but decided to just pull the jack out and step away from the vehicle. I've got an 11:30 tee time tomorrow and didn't want to end up pulling some stupid muscle doing this tonight. Plus somebody said something about 100.00 a hole. I'm a 25 handicap!
Pinebaron, I'll definitely have them look. The last time they said everything looked fine and they blamed it on the aftermarket iRotors, of course.
Old 10-09-2007, 11:18 PM
Long Islander's Avatar
2018 E400 4matic Wagon
A couple of theories
As to why your rotors are warping so quickly, I think brake rotors generally warp when they are heated up (due to use) and then cooled down rapidly. Are you driving through any puddles shortly after some heavy braking? Did you ever wash your car right after a long highway ride or lots of stop-and-go driving? (Yes, I did this once, and I later discovered it warped my rotors).
As to your sticking lug bolts -- they may have been overtorqued, but I've also seen this happen from the bolts fusing to the hubs. I now regularly use anti-sieze compound on the lug bolt threads. I've even had wheels stick to the hubs so that it took a lot of kicking on the tires to get them detached from the hubs even after all the lug bolts were removed.
Old 10-10-2007, 12:10 AM
csumt76's Avatar
When you have them change the rotors, bring your torque wrench with you and check them before you leave the service drive. Then get the service manager out there and explain to him that when they do rotors on your high end luxury vehicle, you would appreciate it if they took the 20 seconds to torque the wheels.
Old 10-10-2007, 03:01 AM
Kar don's Avatar
Mercedes-Benz
torque wrench wont tell you if its over-torqued guys.
What about your pads? Ever replaced? Personally I will only use MB branded rotors from the dealer... why? Just had bad luck from everywhere else. I say try the dealer stuff, if it warps in 5k you can get new ones for free because MB parts carry a 12 month warranty.
Old 10-10-2007, 05:25 AM
pinebaron's Avatar
07 E320 Bluetec
[QUOTE=Kar don;2448397]torque wrench wont tell you if its over-torqued guys.
QUOTE]
That is exactly what your torque wrench will tell you.
Not only can a torque wrench be used to torque correctly but also to check for over torque. Over torqued nuts should be loosened and retorqued.
Old 10-10-2007, 08:25 AM
RobertG's Avatar
things with and without wheels
First of all never use a torque wrench to loosen lug nuts or any fastener,it will loose it's calibration much quicker.
Speaking of calibrating your torque wrench, it should be done at least once a year and if you are using it everyday then at least every 3 months.
Lug nuts should be tightened folowing a crisscross pattern, if you dont do that then you are running a risk of warping your rotors or possibly having a wheel fall off.
Impact gun should be used only to snug up the lugs and the final turning of the lugs should be done with the torque wrench then you know that they are tightened to spec.
If you come across a very tight fastener use a breaker bar with a cheater pipe on the end.
Never use any lubricants on the threads of lug nuts that can lead to lugs backing off and having your wheel pass you by.
Old 10-10-2007, 09:33 AM
NCE500's Avatar
2007 E63, 2006 C55
RE: Lug Torque vs Warped Rotors
I have encountered warped rotors on several cars due to overtorqued lug nuts. Dealers with their impact guns are notorious for this practice.
I have not experienced any brake rotor issues with my Benzes, or other cars for that matter of late, mostly because I always hand torque the lugs when I first get the car, and anytime after the dealer removes the wheels.
I use a 1/4 inch drive Craftsman torque wrench, not expensive and quite accurate, and torque the Benz to 95 ft/pounds.
As fyi for the group, my 07 was pretty much perfect from the factory, but overtorqued big time by the dealer when the 1st diagnostic service was performed. Not sure why they pulled the wheels, but they did and I'm glad I checked them.
Old 10-10-2007, 12:16 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
I think W211 rotors will warp from spraying cold water on them when they're hot.
Old 10-11-2007, 12:01 AM
starbrite's Avatar
2004 E320
Don't you mean 1/2 inch drive ?
Old 10-11-2007, 12:06 AM
lkchris's Avatar
Originally Posted by Kar don
torque wrench wont tell you if its over-torqued guys.QUOTE]
Not a chance. How many times will you reset before you find the "click point?" It won't be accurate in any event, as you can't accurately judge movement.
Yes, if it clicks at 96 and nothing moves, it's probably tighter than that. How much, you'll never know. 98 isn't a problem, of course.
Old 10-11-2007, 01:09 AM
csumt76's Avatar
I'm gonna go ahead and think outside the box here. If your bolts call for a torque spec of.... well let's just say 90Nm..... that sounds like a nice number for a midsize German sedan. If you set the wrench at 90 and it clicks before you get any movement out of the wrench, it's at 90Nm or better right? So now let's set the wrench at 100Nm and try it again. If the wrench again clicks without movement, it's OVER TORQUED! Right? So then we will just slacken the lug bolt, set the wrench back to 90Nm and tighten it properly.
Old 10-11-2007, 04:13 AM
W Cole's Avatar
makes your daughter horny
I think a lug torqued to 90nm will most likely require more than 90nm force to be loosened due to rust, etc.
Anyways, my dealer (Fletcher Jones, Newport Beach) always uses the impact guns to tighten the bolts well beyond spec. So tight that I was unable to get them off myself (I broke my 1/4" adapter clean off trying to). This incident was well documented in the service logs (I ended up taking it into the dealer to get the lugs removed and I made them document it).
After several months and several trips to the dealer later I decided to do my own brake job, when I removed the lugs I found that the hub had been what looks like cross threaded. The threads on the lugs (and I assume inside the hub) are all marred. I used new lugs and they still dont thread into the hub smoothly at all (it makes me cringe tightening them down).
Obviously I dont have 100% proof it was Fletcher who did this but I know for a fact it was them as no one else has ever touched my car except for myself. What recourse do I have?? Any recommendations??
Old 10-11-2007, 12:47 PM
Got this from Luke at Tirerack. Very interesting and informative read, if you have the time.
Originally Posted by StopTech White Pages
The "Warped" Brake Disc and Other Myths of the Braking System
by Carroll Smith
Myth # 1 – BRAKE JUDDER AND VIBRATION IS CAUSED BY DISCS THAT HAVE BEEN WARPED FROM EXESSIVE HEAT.
The term "warped brake disc" has been in common use in motor racing for decades. When a driver reports a vibration under hard braking, inexperienced crews, after checking for (and not finding) cracks often attribute the vibration to "warped discs". They then measure the disc thickness in various places, find significant variation and the diagnosis is cast in stone.
When disc brakes for high performance cars arrived on the scene we began to hear of "warped brake discs" on road going cars, with the same analyses and diagnoses. Typically, the discs are resurfaced to cure the problem and, equally typically, after a relatively short time the roughness or vibration comes back. Brake roughness has caused a significant number of cars to be bought back by their manufacturers under the "lemon laws". This has been going on for decades now - and, like most things that we have cast in stone, the diagnoses are wrong.
With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, in more than 40 years of professional racing, including the Shelby/Ford GT 40s – one of the most intense brake development program in history - I have never seen a warped brake disc. I have seen lots of cracked discs, discs that had turned into shallow cones at operating temperature because they were mounted rigidly to their attachment bells or top hats, a few where the friction surface had collapsed in the area between straight radial interior vanes, and an untold number of discs with pad material unevenly deposited on the friction surfaces - sometimes visible and more often not.
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
In order to understand what is happening here, we will briefly investigate the nature of the stopping power of the disc brake system.
THE NATURE OF BRAKING FRICTION
Friction is the mechanism that converts dynamic energy into heat. Just as there are two sorts of friction between the tire and the road surface (mechanical gripping of road surface irregularities by the elastic tire compound and transient molecular adhesion between the rubber and the road in which rubber is transferred to the road surface), so there are two very different sorts of braking friction - abrasive friction and adherent friction. Abrasive friction involves the breaking of the crystalline bonds of both the pad material and the cast iron of the disc. The breaking of these bonds generates the heat of friction. In abrasive friction, the bonds between crystals of the pad material (and, to a lesser extent, the disc material) are permanently broken. The harder material wears the softer away (hopefully the disc wears the pad). Pads that function primarily by abrasion have a high wear rate and tend to fade at high temperatures. When these pads reach their effective temperature limit, they will transfer pad material onto the disc face in a random and uneven pattern. It is this "pick up" on the disc face that both causes the thickness variation measured by the technicians and the roughness or vibration under the brakes reported by the drivers.
With adherent friction, some of the pad material diffuses across the interface between the pad and the disc and forms a very thin, uniform layer of pad material on the surface of the disc. As the friction surfaces of both disc and pad then comprise basically the same material, material can now cross the interface in both directions and the bonds break and reform. In fact, with adherent friction between pad and disc, the bonds between pad material and the deposits on the disc are transient in nature - they are continually being broken and some of them are continually reforming.
There is no such thing as pure abrasive or pure adherent friction in braking. With many contemporary pad formulas, the pad material must be abrasive enough to keep the disc surface smooth and clean. As the material can cross the interface, the layer on the disc is constantly renewed and kept uniform - again until the temperature limit of the pad has been exceeded or if the pad and the disc have not been bedded-in completely or properly. In the latter case, if a uniform layer of pad material transferred onto the disc face has not been established during bedding or break-in, spot or uncontrolled transfer of the material can occur when operating at high temperatures. The organic and semi-metallic pads of the past were more abrasive than adherent and were severely temperature limited. All of the current generation of "metallic carbon", racing pads utilize mainly adherent technology as do many of the high end street car pads and they are temperature stable over a much higher range. Unfortunately, there is no free lunch and the ultra high temperature racing pads are ineffective at the low temperatures typically experienced in street use.
Therefore - there is no such thing as an ideal "all around" brake pad. The friction material that is quiet and functions well at relatively low temperatures around town will not stop the car that is driven hard. If you attempt to drive many cars hard with the OEM pads, you will experience pad fade, friction material transfer and fluid boiling - end of discussion. The true racing pad, used under normal conditions will be noisy and will not work well at low temperatures around town.
Ideally, in order to avoid either putting up with squealing brakes that will not stop the car well around town or with pad fade on the track or coming down the mountain at speed, we should change pads before indulging in vigorous automotive exercise. No one does. The question remains, what pads should be used in high performance street cars - relatively low temperature street pads or high temperature race pads? Strangely enough, in my opinion, the answer is a high performance street pad with good low temperature characteristics. The reason is simple: If we are driving really hard and begin to run into trouble, either with pad fade or boiling fluid (or both), the condition(s) comes on gradually enough to allow us to simply modify our driving style to compensate. On the other hand, should an emergency occur when the brakes are
cold, the high temperature pad is simply not going to stop the car. As an example, during the mid 1960s, those of us at Shelby American did not drive GT 350 or GT 500 Mustangs as company cars simply because they were equipped with Raybestos M-19 racing pads and none of our wives could push on the brake pedal hard enough to stop the car in normal driving.
Regardless of pad composition, if both disc and pad are not properly broken in, material transfer between the two materials can take place in a random fashion - resulting is uneven deposits and vibration under braking. Similarly, even if the brakes are properly broken, if, when they are very hot or following a single long stop from high speed, the brakes are kept applied after the vehicle comes to a complete stop it is possible to leave a telltale deposit behind that looks like the outline of a pad. This kind of deposit is called pad imprinting and looks like the pad was inked for printing like a stamp and then set on the disc face. It is possible to see the perfect outline of the pad on the disc.
It gets worse. Cast iron is an alloy of iron and silicon in solution interspersed with particles of carbon. At elevated temperatures, inclusions of carbides begin to form in the matrix. In the case of the brake disk, any uneven deposits - standing proud of the disc surface - become hotter than the surrounding metal. Every time that the leading edge of one of the deposits rotates into contact with the pad, the local temperature increases. When this local temperature reaches around 1200 or 1300 degrees F. the cast iron under the deposit begins to transform into cementite (an iron carbide in which three atoms of iron combine with one atom of carbon). Cementite is very hard, very abrasive and is a poor heat sink. If severe use continues the system will enter a self-defeating spiral - the amount and depth of the cementite increases with increasing temperature and so does the brake roughness. Drat!
PREVENTION
There is only one way to prevent this sort of thing - following proper break in procedures for both pad and disc and use the correct pad for your driving style and conditions. All high performance after market discs and pads should come with both installation and break in instructions. The procedures are very similar between manufacturers. With respect to the pads, the bonding resins must be burned off relatively slowly to avoid both fade and uneven deposits. The procedure is several stops of increasing severity with a brief cooling period between them. After the last stop, the system should be allowed to cool to ambient temperature. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid. Game over.
In terms of stop severity, an ABS active stop would typically be around 0.9 G’s and above, depending on the vehicle. What you want to do is stop at a rate around 0.7
to 0.9 G's. That is a deceleration rate near but below lock up or ABS intervention. You should begin to smell pads at the 5th to 7th stop and the smell should diminish before the last stop. A powdery gray area will become visible on the edge of the pad (actually the edge of the friction material in contact with the disc - not the backing plate) where the paint and resins of the pad are burning off. When the gray area on the edges of the pads are about 1/8" deep, the pad is bedded.
For a race pad, typically four 80mph to 5 and two 100mph to 5, depending on the pad, will also be necessary to raise the system temperatures during break-in to the range that the pad material was designed to operate at. Hence, the higher temperature material can establish its layer completely and uniformly on the disc surface.
Fortunately the procedure is also good for the discs and will relieve any residual thermal stresses left over from the casting process (all discs should be thermally stress relieved as one of the last manufacturing processes) and will transfer the smooth layer of pad material onto the disc. If possible, new discs should be bedded with used pads of the same compound that will be used going forward. Again, heat should be put into the system gradually - increasingly hard stops with cool off time in between. Part of the idea is to avoid prolonged contact between pad and disc. With abrasive pads (which should not be used on high performance cars) the disc can be considered bedded when the friction surfaces have attained an even blue color. With the carbon metallic type pads, bedding is complete when the friction surfaces of the disc are a consistent gray or black. In any case, the discoloration of a completely broken in disc will be complete and uniform.
Depending upon the friction compound, easy use of the brakes for an extended period may lead to the removal of the transfer layer on the discs by the abrasive action of the pads. When we are going to exercise a car that has seen easy brake use for a while, a partial re-bedding process will prevent uneven pick up.
The driver can feel a 0.0004" deposit or TV on the disc. 0.001" is annoying. More than that becomes a real pain. When deposit are present, by having isolated regions that are proud of the surface and running much hotter than their neighbors, cementite inevitably forms and the local wear characteristics change which results in ever increasing TV and roughness.
Other than proper break in, as mentioned above, never leave your foot on the brake pedal after you have used the brakes hard. This is not usually a problem on public roads simply because, under normal conditions, the brakes have time to cool before you bring the car to a stop (unless, like me, you live at the bottom of a long steep hill). In any kind of racing, including autocross and "driving days" it is crucial. Regardless of friction material, clamping the pads to a hot stationary disc will result in material transfer and discernible "brake roughness". What is worse, the pad will leave the telltale imprint or outline on the disc and your sin will be visible to all and sundry.
The obvious question now is "is there a "cure" for discs with uneven friction material deposits?" The answer is a conditional yes. If the vibration has just started, the chances are that the temperature has never reached the point where cementite begins to form. In this case, simply fitting a set of good "semi-metallic" pads and using them hard (after bedding) may well remove the deposits and restore the system to normal operation but with upgraded pads. If only a small amount of material has been transferred i.e. if the vibration is just starting, vigorous scrubbing with garnet paper may remove the deposit. As many deposits are not visible, scrub the entire friction surfaces thoroughly. Do not use regular sand paper or emery cloth as the aluminum oxide abrasive material will permeate the cast iron surface and make the condition worse. Do not bead blast or sand blast the discs for the same reason.
The only fix for extensive uneven deposits involves dismounting the discs and having them Blanchard ground - not expensive, but inconvenient at best. A newly ground disc will require the same sort of bedding in process as a new disc. The trouble with this procedure is that if the grinding does not remove all of the cementite inclusions, as the disc wears the hard cementite will stand proud of the relatively soft disc and the thermal spiral starts over again. Unfortunately, the cementite is invisible to the naked eye.
Taking time to properly bed your braking system pays big dividends but, as with most sins, a repeat of the behavior that caused the trouble will bring it right back.
MYTH # 2 - RACING BRAKE DISCS ARE MADE FROM STEEL
To digress for a moment "steel discs" are a misnomer frequently used by people who should know better. This group includes TV commentators and drivers being interviewed. Except for some motorcycles and karts, all ferrous discs are made from cast iron - an excellent material for the job. While steel has a higher tensile strength, cast iron is many times stronger than disc brake requirements. Its thermal transfer characteristics are significantly better than those of steel so that the heat generated at the interface between pad and disc is efficiently carried through the friction faces to the interior surface of the disc and into the vanes from where the heat is dissipated into the air stream. Cast iron is more dimensionally stable at elevated temperature than steel and is a better heat sink - so let us hear no more talk of "steel" brake discs.
MYTH # 3 - A SOFT BRAKE PEDAL IS THE RESULT OF PAD FADE
The all too familiar mushy brake pedal is caused by overheated brake fluid, not overheated pads. Repeated heavy use of the brakes may lead to "brake fade". There are two distinct varieties of brake fade
A) When the temperature at the interface between the pad and the rotor exceeds the thermal capacity of the pad, the pad loses friction capability due largely to out gassing of the binding agents in the pad compound. The brake pedal remains firm and solid but the car will not stop. The first indication is a distinctive and unpleasant smell which should serve as a warning to back off,
B) When the fluid boils in the calipers air bubbles are formed. Since air is compressible, the brake pedal becomes soft and "mushy" and pedal travel increases. You can probably still stop the car by pumping the pedal but efficient modulation is gone. This is a gradual process with lots of warning.
MYTH # 4 - BOILED BRAKE FLUID WILL BE SERVICABLE AFTER IT COOLS.
Once the brake fluid inside the caliper has boiled, it has lost a significant percentage of its original boiling point and should be replaced. It is not necessary to remove all of the fluid in the system, just bleed until clear fluid appears.
MYTH # 5 - BECAUSE THEY ARE NON-HYGROSCOPIC SILICON BASED BRAKE FLUIDS ARE SUITABLE FOR USE IN HIGH PERFORMANCE CARS
DOT 3 AND DOT 4 brake fluids are ether based and are hygroscopic in nature - i.e. they absorb water vapor. As the braking system in not quite airtight, a significant amount of water can be absorbed from the atmosphere in the course of a year. A 3% water content in brake fluid drops the boiling point as much as 170 degrees F. Brake fluid should be completely replaced annually.
DOT 5 fluids are silicon based and are non-hygroscopic, which is good. They are also subject to frothing from high frequency vibration, which gives a soft pedal. Soft brake pedals may be OK in non-high performance cars (in fact, most drivers accept mushy brake pedals as normal) but they are not acceptable in any situation where the driver intends to modulate braking at high force values.
MYTH # 6 - The brake fluid reservoir should be topped up during routine service.
In most modern passenger cars, the brake fluid reservoir is designed with a specific volume and is equipped with an internal float. The volume corresponds to the amount of fluid that will be displaced when the pads have worn to the point of replacement plus a generous reserve. When the replacement point is reached, the descending float completes an electrical circuit and a light appears on the dash warning the driver that the pads should be replaced.
If the brake fluid is topped up the first warning of warn out pads will be the screech of steel backing plate against iron disc. This will be both annoying and expensive.
COPYRIGHT © 2004 STOPTECH LLC
Old 10-11-2007, 09:06 PM
Well guys,
I went and purchased a 150 ft-lb 1/2" torque wrench and now I'm pissed!
First thing I did was check 4 or 5 random lug bolts and found that all of them were torqued past 140 ft-lb and a few of them were torqued beyond 150 ft-lbs!
I had to buy a 4 ft steel pipe and slip it over the lug wrench to break these things loose. Got the first wheel done and moved on to the second. Well, I couldn't even get 1 lug loose! And get this, I ended up bending the damn lug wrench. INSANE! I had to bend the thing back into shape and start over. Well, now the metal has weakened and just keeps bending when I try to loosen the bolts.
So, I go grab another lug wrench out of my R500 and guess what? Yep, bent that one too! WTF!
Now, I'm furious. I have no doubt that this is the reason I'm going through rotors. I don't own any pneumatic tools so now I'm stuck. I guess I'll have to call roadside assistance and have them break these things loose for me.
JESUS!
Old 10-12-2007, 01:06 AM
csumt76's Avatar
Like I said, have the dealer change the rotors and bring the torque wrench when you pick it up. Prove to an authoritative figure that the lug bolts are extremely overtorqued. If they don't agree to comp the labor, rest assured that they will lay down strict rules to the techs about tightening wheel lug bolts. You could save other people some trouble.
Old 10-12-2007, 12:31 PM
Well,
Roadside assistance came out and swapped my wheels for me. Called them at 8:00 am and they said they would be there in 45 minutes. Showed up at Noon. Anyway, the guy complained about how they're only supposed to change 1 flat tire, not 4 good ones. I had already changed one, so really it was only 3. I suggested that it was his dealerships fault that they over torqued the bolts and that they should be responsible for changing the wheels for me. He griped but did it.
Rolling on fly OEM 17's now. **Sigh**
Old 10-12-2007, 01:24 PM
starbrite's Avatar
2004 E320
Well,
Old 10-12-2007, 01:52 PM
Originally Posted by starbrite
I know, I know....
Well, back to this look till next Spring.
Quick Reply: Can overtightening your lug bolts warp your rotors?
