E-Class (W211) 2003-2009
Puting phone in 2005?
Old Oct 15, 2007 | 12:17 AM
jimdvan's Avatar
2005 E320 AMG Sport Package
I've been reading a lot on installing phones but I'm a bit confused. I have an early 2005 E320. The car is pre-wired for a phone but it does not have the cradle. All the electronics are present in the trunk.
What do I need to do to get me going with a phone? What are some of the options?
Old Oct 15, 2007 | 10:07 AM
jallison12's Avatar
2004 E500 Wagon 4Matic
I think, if you do not have the cradle then the "puck with tail" is what you should look for. If you search for this on the forum, I am sure someone has more details on installing. The puck would reside in the top part of the center storage console between the two front seats - are there any wires in there? For me I had the cradle already and just needed to buy the puck (no tail). Good luck!
jim
Old Oct 15, 2007 | 10:14 AM
jimdvan's Avatar
Looking at e-Bay I found I can get the original MBZ cradle and phone for under $200. I have the wiring so it should be a plug-n-play affair. It seems I could always buy a Bluetooth puck to go into the cradle at a later date if I needed to.
Old Oct 15, 2007 | 11:27 AM
lkchris's Avatar
'10 CL550, '12 GL550
http://www.benzworld.org/forums/audi...bluetooth.html
Old Oct 15, 2007 | 01:00 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The car is prewired for the phone but are you Sure that the PSE is in the car installed? as its located under a plastic panel in the trunk
If Not then you will need the phone PSE and cradle..I would also purchase the Blue tooth puc...Voice control (hands Free) is another great option to add also.
Old Oct 15, 2007 | 02:19 PM
carpersn's Avatar
2019 Volvo XC90 Magic/Amber, '95 E320 Cabriolet Midnight,'14 GL350 Lunar/Almond was '07 GL320CDI
jim
Puck with Tail is ONLY made for 03's and 04's because it actually makes use of TeleAid overfunctionality, which was cut out in 05. SO, puck with tail for an 05 will be an expensive lesson in getting nothing for $400.
Old Oct 15, 2007 | 04:03 PM
lkchris's Avatar
If you have a connector for a cradle in your console, you may be good to go.
This same connector will mount a phone cradle or a Bluetooth adapter as you wish.
Old Oct 15, 2007 | 04:50 PM
bigmel's Avatar
2004 E500 4matic
do a Google search for the Mb star phone install bulletin for a 2005 E Class. It will should you the parts and parts numbers of the stuff you will need to complete the install. Also it will show you the location of the parts for you can check for your self to make sure you have it in there. hopefully you will just in the cradle kit (the one the have the connector for the PSE module for the cell for you will like to use).
Old Oct 15, 2007 | 05:18 PM
rhampar's Avatar
11 E550 Cabriolet
Suggest you check http://wireless4mb.com/. They should be able to tell you what is needed.
Old Oct 15, 2007 | 09:17 PM
Benz-O-Rama's Avatar
HERE:
I did the legwork for ya. Everything you need to know is in this document, I think.
2005+PhoneKitRetrofit
Old Oct 15, 2007 | 10:28 PM
georgedaman's Avatar
GL350
Originally Posted by Benz-O-Rama
HERE:
Nice work . Thanks.Do you think its the same for w203?
Old Oct 16, 2007 | 12:02 AM
bigmel's Avatar
2004 E500 4matic
I'm sure its not the same.
Old Oct 16, 2007 | 01:25 AM
jimdvan's Avatar
HERE:
Thanks, great info. After reading the tutorial I'm assuming that just because I have the wiring in the center console and all the parts in the trunk the system may not be hooked up. Is that correct?
Old Oct 16, 2007 | 02:46 PM
lkchris's Avatar
If you just have a connector for that connector, you're not.
You can see this clearly in the instructions.
Old Dec 29, 2007 | 09:07 PM
chemo's Avatar
w211 cdi 2005
where to get parts?
Ok the directions look easy.
So, where do I get the parts? Is the dealer the only option.
smb
Old Dec 30, 2007 | 11:27 PM
bigmel's Avatar
2004 E500 4matic
smb
ebay is another source
