Nav Command install
I was wondering if you can add a NAv display and a nav computer in the trunk and be in business?
If not what other components would I require?
HAs anyone actually done this added an OEM nav unit aftermarket?
Thanks John
Thanks John
Is there a command unit that is self contained and does not require a trunk mounted nav unit?
John
PM me and I can tell you more about it. I had to go through same thing on my 2003 E500 and it is definitely doable. The answer to your question is that you CANNOT get a self-contained COMAND unit with intergrated NAV system.
Alex
