What is the dvd drive for? Also difference betwee C and S mode?
I have an 08 E350 with 6 disc cd changer. I noticed there is a dvd drive ontop of the navi. I was told the dvd disc for the navi is in the trunk, so what is the dvd drive in the front for?
also, what sthe difference between comfort and sport mode? suspension or just where it shifts? i think sports mode revs higher
In case you didn't have the 6 cd changer you would still have a cd player. Probably standard.
You have to go to the audio option on the screen and it will give you the choice of either CD or 6CD.
On mine, the in-dash unit will play .mp3s as well as audio CDs. You can burn an awful lot of tracks on a DVD. A couple of those makes a cheap ipod alternative if you have a DVD player with .mp3 capability.
'06 E500, '99 ML430 and '07 SL65
On an E350 the difference between C and S is the shift points and that the car starts from a full stop in 2nd gear. On a car with airmatic it will also lover the body when you drive faster than a given speed (that I can't remember).
You will notice that the throttle gets a little more 'spongy' when you use C mode.
The tranny program may appear confusing when early models used S & W, and new mostly use C & S. Comfort and Winter should be pretty similar and Sports & Summer, perhaps the change of name with the 7G-tronic where start with second gear (C) is seen the default mode and Summer the default on older cars. Some call Winter "Wet", better in Florida or so
2015 ML 350
When you put a CD into the single slot, the soft key for it will be illuminated as a choice, as well as the CDC button.
2015 ML 350
C & S Mode
With the transmission in Park, pressing that button changes the shift point program the transmission uses and also eliminates 1st gear. "S" uses 1st and is a more aggressive shifting program, "C" starts the car out in 2nd & is smoother shifting, both up & down.
Comfort & Speed settings ?? Who knows?
