Ambient light removed for 2008?
First off I have a Canadian 2008 E300 4matic
This is my current rear dome and you can see that it does not have the normal white ambient light ring.
This is the connector for the rear dome light. It has a tab on it that makes it fit only one way and has 4 wired pins.
You can see the underside of my original dome light on the left. The jack for the connector is circled in red. On the right is the new dome light with ambient lighting. The jack for both of these dome lights are identical.
Here is the interesting part. The ONLY thing that works on the new dome light are the reading lights. Everything else does not work. The ambient lighting, the backlights on the buttons and the dome light (when the doors open) all do not work. Would the car have to be programmed for the new light?
