E-Class (W211) 2003-2009
warranty question
Old Nov 18, 2002 | 11:14 PM
yipikaye's Avatar
2000 E-class
warranty question
hi guys, i have a quick question
1. will my warranty void if i put aftermarket cd changer?
Old Nov 18, 2002 | 11:32 PM
bmms8's Avatar
MB
you have to ask your dealer, because i think electrical wiring differing will void it, unlike tires, or rims
Old Nov 19, 2002 | 03:53 PM
Benzoid's Avatar
03 E500, 01 SLK320
Is there an aftermarket CD changer available that is plug in compatible with the E? I for one would like to install one if so.
If so I don't see any warranty problem unless you are doing something that would be electrically different or you are splicing into wires in some way.
On my 01 SLK 320 I have a trunk mounted Becker that uses the same optical interface and plugs as the MB factory changer. I have no idea what would work in the E. It works through the factory radio exactly like the MB unit.
