E-Class (W211) 2003-2009
Wierd AC issue! Please help!
Old Mar 24, 2008 | 08:30 PM
MB500's Avatar
2021 Tesla M3SR+, 2017 GLS550, 2011 E350 Bluetec, 2007 GL450 (GONE), 2003 E500 (GONE)
Having a rather strange AC problem on my W211 and hoping that someone could help. When I turn AC on, I get plenty of cold air through the front vents, however, there is hot air coming from the rear vents. No matter what temperature I set on the rear control unit, the air is still very hot, as if the heater is set on its very warmest setting.
Can anyone provide any clues? Do you think that the rear control unit maybe faulty?
Thank you in advance!
Old Mar 24, 2008 | 09:11 PM
konigstiger's Avatar
'71 Pinto
Common problem, the heat exchanger valve needs to be replaced.
https://mbworld.org/forums/e-class-w211/215525-my-heater-will-not-blow-hot-air.html
DIY https://mbworld.org/forums/e-class-w211/216187-plastic-trim-bottom-windshield.html
