Brake Hold Function
Not all electronic control units are SCN coded. I did not check if Hold is covered by SCN in Europe though. Also, isn't SCN fixed for a specific car with the options list, or could a change in the SCN "release" a parameter for individual settings?
Anyway, will be interesting to hear what konigstiger finds out, the bulletin clearly indicates that Hold would at least be on the way to the US if not already activated on some cars.
Let's hope that konigstiger comes up with some good news.
So after talking to some guys downstairs and doing some research, this function is only available on european units with a form of distronic that is not available here in the US...Apparently the stalk for the cruise control is even different on our cars than the european ones that have this capability.
To make a long and vague story short, it doesnt work and is not functional on our cars...unfortunate I know, I really wanted this to work...
Received 4,435 Likes
'71 Pinto
So after talking to some guys downstairs and doing some research, this function is only available on european units with a form of distronic that is not available here in the US...Apparently the stalk for the cruise control is even different on our cars than the european ones that have this capability. To make a long and vague story short, it doesnt work and is not functional on our cars...unfortunate I know, I really wanted this to work...
No mention of Distronic or stalk association in European manual:
HOLD
- when pulling away, especially on steep slopes
- when maneuvering on steep slopes
- when waiting in traffic
The vehicle is kept stationary without the driver having to depress the brake pedal.
The braking effect is cancelled and HOLD deactivated when you depress the accelerator pedal to pull away.
Activation conditions
- the vehicle is stationary
- the engine is running
- the driver's door is closed
- the parking brake is not applied
- the bonnet is closed
- on vehicles with automatic transmission*, the selector lever is in position D, R or N
Activating HOLD
Make sure that the activation conditions are met.
Depress the brake.
Depress the brake again quickly until HOLD appears in the display.
HOLD is activated. You can release the brake pedal.
If depressing the brake pedal the first time does not activate HOLD, wait briefly and then try again.
My contact will not return from Germany until the 24th - curious to find out Montvale’s official explanation of DTB release.
1 Post
4 wheels
No and Yes on HOLD....
W211 USA definitely does not have it and never has and likely never will. Yes, they had it on ECE models but the legal environment is a bit different there. The R230 also has this on ECE models. However, the USA MY09 S-Class will have this feature representing the market introduction of this feature on an MB. Let's hope the next E-Class gets it.
I agree, HOLD does come on (Euro) cars that do not have distronic or distronic plus. Actually I don't see any connection with distronic, even on the S/CL, can you clarify? The car does stop with Distronic Plus and remains stationary until driver taps the cruise or presses gas pedal but the "Hold" indication does not come to the cluster in this case.
#32
W211 & Q7
MBUSA gets rid of HOLD to reduce cost
This is a pure cost issue in US W211 -- It is not a legal issue. My Audi Q7 comes with a hold feature. I think MBUSA should provide this feature for a safety reason. (My 2 cents is -> If you have to press brake on a slope to prevent your car rolling back -> your car is NOT a luxury car -> you are doing an action which should be done by your car.)
#33
Aside from the HOLD feature being indicated in the display, how does this system differ from the existing "hold" feature in our cars, or at least mine, 'cause my car seems to have this hold feature (excluding the HOLD indication in the display).
I can take my foot of the break on a level surface, and the car won't move until I hit the gas. Alternately, on an incline, I can take my foot of the brake and the car will not move backwards down the incline.
Isn't that the "hold" feature being discussed here?
#34
Administrator
Boy, this thread is confusing me.
I believe that this thread is discussing this feature with regular brakes only. I might be wrong but your brake setup differs from later MYs based on your info provided under your avatar.
#35
I have to say I do not remember for sure about the W211, I tend to remember my car indicating HOLD at the IC display. My W221 definitely has that. Actually this is from the W211 Euro manual:
HOLD
- when manoeuvring on steep slopes
Depress the brake.
The incline case does not need to be the Hold feature but if you say you can make your car stay in place, gear on, at level surface, this sounds like Hold. Do you mean it moves forward except if you specifically activate Hold with the brake pedal (press first to make the car stop moving and then press with more force again shortly and release the brake pedal)?
#37
At least, mine does not have. This topic was discussed before, the alternative solution is use "W" or "C" mode (2nd gear start) to hold your car on a slope.
But my question would be more on your cost claim. Which parts do you see different on US cars compared to Euro models? There may be a difference but I have not found any. Leaving one dollar part out from US cars would cost more for MB than the saved dollar (when ROW is using this low cost part). I'm guessing this is a SW option, meaning additional cost (even if marginal) when the SW variant is only needed because of the US market.
I would be glad to see the parts difference analysis.
#38
#39
I've never (conciously) applied the brakes as you indicate to have the car HOLD. All I've done is slowly take my foot off the brake pedal, and 9 times out of 10, the car just sits there. A few times I've thought "gee this must be messing up the guy behind me, 'cause I'm guessing my brake lights might not be lighting up if I don't have the pedal applied".
If you gently press the brake pedal to stop the car, and then release the pedal, Hold should not get activated.
Could you specifically have a look at the IC display if it does indicate Hold.
#40
Hillholder vs. HOLD
There appears to be some confusion between two different features. HOLD and Hillholder. Hillholder simply keep you from rolling when at a stoplight. Depending on your MY, this is a function of whether you are in C or S mode. HOLD, which is not on USA cars, is activated as explained earlier, by a second pressing of the brake and will hold the car in place indefinitely. A corresponding message will appear in the IC which says HOLD. MBUSA not having this is certainly not a cost issue - only their concern and interpretation of the legal ramifications. As this will be implemented on the S-S-Class with MY09, I would assume this opinion has changed.
#41
'71 Pinto
Silberrosa let me approach this in a different way. Simply why did MBUSA release DTB P-B-42.45/97 on March 24, 2008 – 211 as of MY07 “Brake Hold Function Cannot Be Activated” inclusive of several resolves to activate?
#42
2004 E500 / 2001 C240
I would love to have this feature. I always thought that it is in the car, it just needs to be enabled.
I really dislike holding my foot on the brake at lights.
Let me know what you guys find out.
#43
#44
Would you be kind enough to test your car a bit, to the interest of the rest of us? Sounds strange if you get the Hold activated 9 out of 10 times when normally applying brakes.
IC does not display anything.
Car does not roll backwards on an incline, stays still when taking the foot of the brake on level surfaces, but the brakes DON'T hold when on a decline. So, maybe I am just experiencing "hill-holder"?
#45
Administrator
3 initials are the reason: JDP
Too many owners/consumers don't RTFM, don't understand, dont comprehend, etc and therefore give negatives on ratings. Do that in a domestic and they shrug their shoulder. And lets not forget the wisdom of DOT in some instances.
$0.02
$0.02
#47
'71 Pinto
According to MBUSA engineering, this DTB was released in error “HOLD” does not apply to USA vehicles. Furthermore, the function cannot be activated in SDS. BIG SURPRISE! The understanding is that the DTB will be unpublished soon.
FYI: The MY09 S-Class will be equipped with “HOLD” therefore it makes sense that the 212 will also have it.
#48
DOT? Nope. None of the issues we're talking about are remotely assocated with any regulatory/safety DOT issue.
#49
#50
I wanna bring this topic up again since so many asked me about it and I was curious about it too. The cars sold everywhere are primarily seen and compared built the same for the entire world. Many features are controlled by the country settings in different ECUs (micro controller basically).
If this feature with a SBC system is available in Germany then why not in the US. If one is able to change the country settings shouldn't it be possible to gain this feature here in the US?
