E-Class (W211) 2003-2009
Brake Hold Function
Old Apr 9, 2008 | 10:50 PM
konigstiger's Avatar
'71 Pinto
Arrow Brake Hold Function
As of 2007
211.022 (Bluetec), 056 (e350), 072 (e550), 077/277 (e63), 087 (e350 4matic), 090 (e550 4matic), 287 (e350 4matic wagon)
HOLD
Depress the brake. Depress the brake again quickly until HOLD appears in the display. HOLD is activated. The vehicle is kept stationary without the driver having to depress the brake pedal. Braking effect is cancelled and HOLD deactivated when you depress the accelerator pedal.
If you receive message “Hold Cannot Be Activated!” the rear SAM is missing battery sensor data and battery sensor will be checked and replaced if necessary.
Old Apr 9, 2008 | 11:59 PM
pinebaron's Avatar
07 E320 Bluetec
Thanks. Great feature; I will try this out tomorrow on my Bluetec.
As of 2007
HOLD
Old Apr 10, 2008 | 07:42 PM
cyclerider's Avatar
Harley-Davidson
I can't activate brake hold or get any messages on the MFD.
Old Apr 10, 2008 | 08:58 PM
'71 Pinto
If code 807 lists on your datacard the DTB applies.
Old Apr 10, 2008 | 09:35 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
As of 2007
HOLD
So push the brake pedal in gently or normally, then release it, and pretty much push it down as hard as possible and hold until that message appears? Where do I find this 807 code?
Old Apr 10, 2008 | 09:36 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
Dont know what the datacard is...just looked through my books and found nothing.
Old Apr 10, 2008 | 11:28 PM
pinebaron's Avatar
07 E320 Bluetec
I tried in my Bluetec today and it did not work.
Old Apr 11, 2008 | 10:14 AM
cyclerider's Avatar
Harley-Davidson
My datacard lists this code : 807 AEJ 06/1/M/X
Is there a reference number for the DTB? My dealer usually doesn't know about these things without some help.
Old Apr 11, 2008 | 12:47 PM
'71 Pinto
My datacard lists this code : 807 AEJ 06/1/M/X Is there a reference number for the DTB? My dealer usually doesn't know about these things without some help.
Check your email.
Old Apr 11, 2008 | 01:11 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
me either...damn it...this sounds so cool i want it to work, especially driving around chicago..
Old Apr 11, 2008 | 06:33 PM
Thom's Avatar
2008 E320 Bluetec, 1987 300D Turbo
My datacard also lists SA Code 807, but the hold function doesn't work for me.
Old Apr 11, 2008 | 07:01 PM
'71 Pinto
I was under the impression that North American vehicles are not equipped with the Brake Hold feature. However, after reading the DTB I am not so certain anymore. That is to say, if the datacard lists code 807 and the feature operates via the rear SAM in accordance to the DTB an assumption would be through SDS a tech could successfully program the feature to operate if not initially equipped as such. I sent an inquiry today – hoping for reply sometime next week unless of course another member provides viable info before then.
MY07 = 807 AEJ06/1/M/X (MY06 = 806 AEJ05/1;05/M)
Old Apr 11, 2008 | 07:48 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
My build date is 07/06 (MY07) and I show 807 AEJ06/1/M/X on my data card. But I do not get either indication in my IC. Talking to my SA I'm told that code 807 for him shows Technical Modification.
Old Apr 12, 2008 | 02:55 AM
Diesel Benz's Avatar
Technical modifications as of model year 2007? Code 80x has always indicated the change of model year. Some odd changes might occur in the middle of the model year, don't know when exactly the brake hold was supposed to be release for the US market though.
Old Apr 12, 2008 | 07:48 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
For those looking for more info on this; here is what I found on the German MB site:
Adaptive Brake - English
Adaptive Brake - German
Old Apr 12, 2008 | 12:45 PM
lkchris's Avatar
'10 CL550, '12 GL550
This would be in owners manual wouldn't it?
Sounds like a perfect candidate for decontenting of USA models in order to cope with falling dollar.
wmhjr's Avatar
My '08 E350 4Matic doesn't have it. It has a Feb 08 build date.
Old Apr 12, 2008 | 02:19 PM
Can you explain how did you conclude your car does not have it? I mean it may not be straightforward to activate hold when trying the first time.
If MBUSA has a bulletin on it, someone I guess should have it. If someone has it, I guess a February 08 build date car should have it.
Old Apr 13, 2008 | 09:27 AM
wmhjr's Avatar
Sure.
1) It's not in the manual whatsoever - including in the online "newest" pdf version of the manual on MBUSA.com.
2) I tried both your method as well as that listed on the link earlier in this thread. No dice.
3) It's not listed anywhere on any documentation (marketing, presales, sales, etc) for the vehicle.
I'd really like to have it and hope I'm overlooking something, however I believe this is just another feature that is not available for we in the US.
Old Apr 13, 2008 | 12:16 PM
This feature was available on Euro cars already before the face-lift. Not on the first sedans but from perhaps late 2003 onwards. So US has been missing it for a long time.
On the pre-face-lift car it was simply SW, not cost savings from leaving it out. I have not checked the face-lift part numbers, with traditional brakes this actually introduces some additional cost. I would guess leaving it out from US cars would not mean any over-all savings. Probably disabled with SW (or would anyone have looked at this in more detail).
It appears clear now from wmhjr's tests that this hold feature does not appear on current US E-class cars.
Old Apr 13, 2008 | 03:29 PM
'71 Pinto
I reiterate:
Indeed, it is not in the MBUSA manual however, MBUSA released DTB P-B-42.45/97 MAR08 to correct a possible malfunction for this feature and this is this basis for my posting and bringing it to the forefront of everyone’s attention. I should note that the DTB specifically mentions SDS has a function check for the “hold” function. Have patience, I am hopeful I will receive a definitive answer sometime next week.
Old Apr 13, 2008 | 04:00 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I reiterate:
And it is appreciated that you post this and other items of interest to forum members.
Yes, it is not in the manual. Therefore the instructions where linked. The only issue I can see is the fact that access to the US version SW seems to be more restrictive than the ROW version SW for those that hope to get this feature working properly or activated.
Old Apr 13, 2008 | 04:26 PM
'71 Pinto
Understood however, my interpretation of the MBUSA document (DTB) implies that MBUSA techs do already have access to the corresponding SDS menu in order to diagnose malfunctions and as such, I would believe the necessary application to function code as well.
Old Apr 13, 2008 | 04:34 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
But the still may have to get approval due to SCN coding.
Old Apr 14, 2008 | 01:55 AM
Not all electronic control units are SCN coded. I did not check if Hold is covered by SCN in Europe though. Also, isn't SCN fixed for a specific car with the options list, or could a change in the SCN "release" a parameter for individual settings?
Anyway, will be interesting to hear what konigstiger finds out, the bulletin clearly indicates that Hold would at least be on the way to the US if not already activated on some cars.
