E-Class (W211) 2003-2009
E500 26mpg
Old May 6, 2008 | 12:02 AM
E2233's Avatar
2000 E320 2009 E550
E500 MPG
Originally Posted by ss3964spd
On Saturday I took my first extended highway trip with my new to me '05 E500. The camara phone photo below is a bit dark and not especially clear but here's the details.
I had stopped to fuel the car and got right back on the highway. This photo was taken about 2 hours after the re-fueling. 142 miles and an average speed of 70 MPH.
Look closely: 29.6 MPG
Looks like the MPG increased after Model Year 2003 for the E500. Were you driving on the flats without hills and very light traffic?
Old May 6, 2008 | 09:38 AM
ss3964spd's Avatar
2011 E550 (RIP), 2014 CLS 550C4
No. I85, between Roanoke and I66. Rolling hills - some steep, moderate traffic, and a number of - um, blasts to dispatch some slower moving traffic and to verify the recently replaced speedometer was working correctly.
The photo above is the last of the probably dozen I took. First was shot at a little over an hour after the re-fueling and I wasn't using the CC - that one showed about 27.7 - which I thought was impressive. Then I noticed that it kept slowly creeping up. I'd snap a pic, thinking it's not going to get any better. Engaged cruise, set it at 75, and tried to stay off the pedal. If I had to brake I'd use the pedal to gently return to 75 then re-engage cruise. "No way is it going to get any better than 28.5" - click. Wow, 28.7 - click. Etc-etc. "These people are never going to believe me". 28.9 - click.
No idea how accurate the computer is but I don't imagine it's that far off. I was happy with 27 MPG!
Dan
Old May 6, 2008 | 10:48 AM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
I would imagine the higher mpg is from a RWD model. (I have the RWD, wouldn't have it any other way-just pure fun factor), PLUS the RWD came with the 7 spd. auto. Weight too may play a factor, all contributing to a better MPG - just my speculation.
Old May 6, 2008 | 11:46 AM
ss3964spd's Avatar
Yes, it's RWD only - not 4M.
I imagine the 7 speed transmission helps, but I believe the impressive fuel milage is more a function of the the transmission's top gear (7th) ratio and the final drive ratio (differential gears) being well matched to the engine torque curve. I noted that in order to simply maintain 75 MPH, via the pedal or the CC, the torque converter never unlocked, nor did the transmission down shift. The engine makes sufficient torque at 2000 RPM to maintain the vehicles' set speed - even up hills, with little additional throttle or a down shift. The only time it would unlock the converter and drop a gear (or two, or three) was when I needed to gain speed quickly.
Dan
Old May 6, 2008 | 01:36 PM
E500Newbee's Avatar
2005 MB E500
Dan
It's great to have a V8 do that huh...man, but I was driving around the city yesterday with AC on blasted. I got to tell you guys. I get around 16-18 is the highest. Highway is the way to go for this car...
Old May 6, 2008 | 11:07 PM
gnma's Avatar
Dan
She's simply an amazing machine. I know she makes 339ft/lbs of torque @ 2,700 rpm's but I'd love to see the power curve graph of the E500. I would imagine she's making 300ft/lbs of torque @ 2000rpms, but don't know for sure.
