E-Class (W211) 2003-2009
sirius unistall problem
Old Apr 28, 2008 | 02:40 PM
locomercedes's Avatar
2007 CLS550 Designo; 2009 Mini Cooper; 2011 BMW 335d
So I uninstall the Sirius module in the trunk. But after unplugging the connector, the Comand won't turn on. If I plug it back it goes back to normal. In other words, the Comand is not letting me uninstall the Sirius module. Any ideas why? I don't see any place where the connector would connect to; I'm thinking it just sits there without plugging into anything when Sirius is not installed. Maybe I need to unplug a connector in the back of the Comand head unit?
Old Apr 28, 2008 | 04:56 PM
konigstiger's Avatar
'71 Pinto
The MOST cabling needs reconfiguring and the dealer needs to version code the MOST ring (fiber optics that links the headunit, AGW, etc.) through SDS otherwise "intermittent malfunctioning of some or all components" may occur. You can trace back the coupling cable and disconnect/reconnect properly yourself but you will still need the dealer or someone with SDS access to code the ring.
Old Apr 28, 2008 | 05:03 PM
Barry45RPM's Avatar
2015 ML 350
Think of the old style of Christmas light strings where all of the bulbs would go dark if there was 1 bad or missing bulb in the string.
Old Apr 28, 2008 | 09:27 PM
thanks guys
