E-Class (W211) 2003-2009
Euro Comand Bluetooth
Old May 5, 2008 | 02:13 PM
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
Can I connect my black berry to the bluetooth in a euro comand? If so how?
Old May 5, 2008 | 03:06 PM
Diesel Benz's Avatar
I guess you want it for telephony, not just to upload a phone book (if this Comand has a local phone book)? A 2003 car should not have UHI, if you have a phone kit, you could install a ViseeO BT adapter.
Old May 6, 2008 | 03:31 PM
djmallya's Avatar
Diesel B, you totally lost me! I don't know what you mean.
Old May 6, 2008 | 06:34 PM
jallison12's Avatar
2004 E500 Wagon 4Matic
Do you have the blue tooth puck installed already? If so, you press down the little blue button for 5 seconds. This puts your bluetooth puck in discoverable mode. Fast flashing blue button if I recall. Then go to your BB and search for BT devices. Should find "MB Bluetooth" or something like that.
I did it successfully with my work BB, but typically I leave my personal phone (MotoQ) connected. I don't want my work to bother me when I'm in the Merc
If this is not enough info, you may want to search the forum. BT puck has been discussed many times. Officially, MB only had like 4 Motorola phones as compatible. But if you find the threads, all sorts of phones from all sorts of carriers have been found to work just fine. My BB is a case in point.
Good luck!
Old May 7, 2008 | 01:31 AM
OK, this must be a US car with a Euro Comand? No Euro phone kit then and ViseeO would not be an option either.
If it does not have the BT puck mentioned above, does it have any phone kit? BT from the Comand would not give hands free calling.
Old May 7, 2008 | 02:27 PM
djmallya's Avatar
OK, I should have been clear from the start. You are correct, I have a US model that I upgraded the APS 50 for a Euro Comand; and I don't have the BT puck.
Is there a way I can make the comand find a BT phone rather than: comand to puck , then puck to phone?
Old May 8, 2008 | 05:12 AM
No, not for hands free telephony.
I believe it actually was Audio 50? Audio 50 APS is a Euro device with navigation.
