InCarTronics (Formerly EuroCarPhone) new Hands Free Kit
anyone know whether i'd need it recoding?
also, could i expect the mobridge to plug and play as people are suggesting the incartronics system does?
with no previous experience of installing such kit, is it really easy enough for a novice to install or will i regret not handing it to a professional?
Also, I was able to get the blackberry to pair and upload the phone book to the H.U. I had a bluetooth setting on the phone set wrong. Once I fixed that and charge the phone - no problem.
Any clarification you can provide would be helpful.
The car then needs version code updating to work.
Steve at MBenznl.com supplied the equipment for me and did the installation. The voice recognition module is also not necessary, but worth buying if it's in the budget.
-David
-David
I don't know how to install it
Can you help me, please?
Do you have a install manual for Mercedes C 2006 (w203)?
I own a 05 C230 with a CD changer -- Will I need to remove it from the back of the stereo or is the fiber optic cable also behind the astray? Removing the stereo unit seems more involved.
You should go for it. You'll feel a great sense of accomplishment when you're done.
Opinions; very cool!
- install took 1-2 hours. alittle confused on wiring up pwr/gnd whether to the CD player or lighter 12V. go with the 1st (always on w/CD player) 'cause the iTronic does have a sleep mode.
- pairs up very easily and it immediately acknowledges when I enter the car, within 5 secs.
- odd that the steering controls/dash is different from the COMAND system, ie. scrolling thru phone book is separate search on either.
- bummer that I can't do txt msging thru BT. COMAND system show SMS function and apparently the iTronic unit can but my Blackberry 8300 doesn't have that capability
- supplied microphone is pretty good! while driving 45mph, the wife at home says the voice quality is as good as a direct line w/no background noise.
-Install went fine. As stated previously, go with the CD player wire instead of cigarette. I chose the latter and the radio would stay on for 30 seconds after the car was off.
-Phone book downloads and incoming calls are fine. Outgoing is a little strange in that it only works half the time. It seems I need to hit a button on the phone before it will recognize the command for making a call. Once I have made one call, all outgoing work fine until I shut off the car. Probably a Treo thing.
-The Mic is great. People say it sounds better than being on the phone directly.
I must say that the unit is functioning as promised. I took their advice and installed the additional microphone that was provided in the kit.
It paired well with my Razor, but it wouldn't pair with by blackberry. Making and receiveing calls is a breeze. Also, call quality is very good.
The one thing that I didn't expect, but kind of makes since is that the dash reads "No phone" unless I approach the car with my razor open. Once the car is started, the phone pairs immediately. I can then close the phone. I believe that this may be a bluetooth setting in the phone. If the phone is open the device pairs immediately.
Also, if someone leaves a voice mail, the envelope lights up on the stereo - very cool.
At this point in time, I'm very happy with incartronics. Everything for my car was truely plug and play.
The only think is, they were surprised why the phone menu was not available in the first place. I didn't tell them that I have a third party bluetooth module installed in my car a couple of days ago. I'm not really sure whay happened but I think installing the iTronics and updating the software in my NAV has something to do with it. Anyways, I don't care. What's important is it's working.rdsbenz
How much was the install from Autotech Security?
Is Fletcher Jones the dealer where you bought your car? If not, why did they do it for free? Did they bill it as warranty work?
I didn't buy my car at Fletcher Jones. I just told them that I just got my car like that and when I paired by iPhone with the bluetooth in the car, it worked with the Nav but the cluster's phone menu is not present and I don't have steering wheel control to make /receive calls. I didn't tell them that I have an aftermarket bluetooth module though.
The service manager ask one of the techs to take a look at it and they told me it will only take 10-15 minutes to version code my cluster. No workorder was needed. I guess it's just one of the perks you get when visiting a Fletcher Jones. I'm not sure if all dealers will do the same.If the dealer didn't fix the problem with my cluster, I probably would have raised some hell
with InCartronics. Oh by the way, the SMS function in your NAV will not work with the iTronics. You won't get any Text messages in your NAV only on your phone. Can anybody who installed their own iTronics confirmed this. . . rdsbenz
I think the itronics and mObridge (many same they are the same) are pretty much the best options. If you try to do it yourself...they should be less than $1000.
