Planning to buy an E500
Most cars that I looked in my price range are already out of warranty. What should I expect in maintenance/repair cost per year.
Should I look for an aftermarket warranty?
Thanks in advance
Maintenance will be expensive if you're not used to MB prices. For instance, an oil change is $120.00. I wouldn't drive one of these cars without some sort of warranty unless you're completely familiar with it's history. Meaning, it was a family member's car and you know everything about it.
I am in Canada and MB extended warranty runs out at 75k. Do you guys know any good aftermarket warranty in Toronto?
Does that seem out of line, guys?
I can tell you that 1 lower ball joint, which is a common repair on these cars, will run you about $750.00 and if you lose an air strut, you're looking at about $1500.00. The engines are pretty much bullet proof in these cars if maintenance was kept up but suspension parts and electrical gremlins are a common source of headache for the early W211s.
Good luck, it's a fine, FINE car if you get one that's not sick.
Definitely allow $1200 to $2000 USD per year for unforseen, non routine services. An extended warranty will come in handy, though.
Thanks in advance
Keep in mind the 7 spd. is avail. only for RWD, and I do bel. the 7spd came out in 2004 - (just had this clarification elswhere on here in the W211 forum). And it is as smooth as silk!
Also the command screen was the smaller version in '03. (Not sure about '04).
Airmatic is standard on the E500, and is $$$ to fix. Research airmatic. BUT the ride is amazing!
I've had my '05 RWD for 6 months with an ongoing tire balancing issue, but the car is amazing! Rock solid, and can you say German hot rod on wheels?
I've given you a few items you should know about concerning what options were avail. for what years. As others suggested, you need a warranty, and it seems the '03 did have problems. If you have a car history, you can see what was repaired. It seems that those 211's that had the repairs, perform very well. Good luck!
