E-Class (W211) 2003-2009
Audio 50
Old Jun 26, 2008 | 08:36 AM
Clinton Horn's Avatar
2003 E320
Audio 50
I have a 2003 withan Audio 50 radio. Car was bought used and after some time I discovered that the tweeter for the driver side had been removed. No idea why. This disables the door speaker, possibly the footwell and of course no A pillar tweeter. I finally located and purchased a set of tweeters with covers in Stone color. Connecting the tweeter to the audio out put is a breeze. There is a second connector that I assume powers the door speaker. In my investigation, I could get the door panel loose enough to expose the poly moisture barrier but after I removed all of the speaker mounting screws, I could not remove the speaker. Again I am assuming the male end of the connection is on the back of the speaker. I really don't want to remove the poly but I will if I must. I would like some advice.
PS if you have a real need for either left or right tweeter cover in Stone, I will share it with you for the cost of the postage. I did not get the foam backing. Obviously, I am keeping the tweeters.
