E-Class (W211) 2003-2009
03 E500 Rotor Replacement
Old Aug 10, 2008 | 12:17 AM
orlzx6r's Avatar
I've got a 03 E500 and need to repalce the front rotors. I found a few threads about replacing the brake pads, but not the rotors. I want to know if the wheel hubs are built into the rotors and if the bearing need to be repacked when replaced. If not I think I can do it, just would like to find out before I order the parts.
Any idea?
Old Aug 10, 2008 | 06:57 AM
shuor's Avatar
04 Civic Hopefully an 00-02 E55 one day
removing the rotor does not require the wheel bearing to be repacked. there should be 2 bolts (probably 18mm) that hold the caliper bridge. then there's 1 torx or allen that holds the rotor. hammer them off. if there's rust use some sort of wd-40 or equivalent to get it off. good luck
Old Aug 10, 2008 | 11:33 PM
orlzx6r's Avatar
Thanks Shuor, that did the trick. I used some PB Blaster and let it sit for a while and a few smacks with sledge hammer it was off.
