E-Class (W211) 2003-2009
Weird tire pressure message
Old Aug 31, 2008 | 12:28 PM
jyeh74's Avatar
I have an 08 E350 and about 12,200 miles. I'm due for my first oil change at 13k miles. Yesterday, there I got a message when I turned of my car "check tire pressure" So I think its probably a flat tire due to a nail because tires don't just lose air. But I checked today, and the tires don't look flat and when I start and turn off my car, the message is gone. Has this ever happened to anyone before?
Also, how do we check if we have run-flat tires (18 inch sport package)?
thanks!
Old Aug 31, 2008 | 01:46 PM
GGM's Avatar
GGM
2008 E350
I had the same thing happen last week (and I only have 8500 miles). I also have the sport package with 18" wheels. I don't think we have run-flat tires but I have had people tell me I have a flat tire because they aren't used to seeing the low profile tires. I have the Continental ContiProContact tires.
1. Read the manual (beginning on p. 296).
2. Get a tire gauge and check the pressure in all 4 tires.
3. Adjust pressure until it reaches the recommended pressure on the gas filler door or the front driver's door post.
4. Then reset the monitor. (It's in the manual).
5. Be prepared for the "STFM" posts.
Tires can and do lose pressure over time.
Hope this helps.
Old Sep 1, 2008 | 01:01 AM
jyeh74's Avatar
Thanks for the reply. What is "STFM"?
I thought there was a way to view all four tire pressure from the instrument gauge, or is that only in the S-Class?
Old Sep 1, 2008 | 05:51 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Search The Fantastic Manual
Old Sep 1, 2008 | 03:49 PM
GGM's Avatar
GGM
2008 E350
When you read the manual you will find that Canadian E-Classes have the active tire pressure monitor that gives you a readout of the pressures. Not sure about the S-Class since I don't own one.
HTH
Old Sep 1, 2008 | 06:07 PM
Untertürkheim's Avatar
Have you ever manually checked your air pressure?
