E-Class (W211) 2003-2009
Bluetooth phonebook not updated
Old Sep 14, 2008 | 01:38 AM
mspaul's Avatar
2018 Macan, 2018 Panamera Turbo S E-Hybrid, 2024 G63
My bluetooth works perfect, connects and downloads phonebook, but the phonebook is nut updated with new numbers.
I had added a new number that day and when in the evening I was in the car, browsing through the phonebook on the command, I could not find the new phone#.
Is there a way to re-sync phonebook with command?
Old Sep 14, 2008 | 07:18 AM
baxterdown's Avatar
1972 280SE 4.5
Try unpairing and re-pairing the phone.
More importantly, where are you adding the new number? If your address book is on your phone and you add a new name to your SIM card, naturally the new name won't download. Make sure you are adding new entries to the same spot where the old ones are.
Old Sep 14, 2008 | 02:30 PM
mspaul's Avatar
Thanks for your tip.
The problem was solved by your second tip but the other way around.
Command was showing all contacts from my SIM phonebook and the new number was on the phone phonebook, I'll copy the new contact to sim phone book and see if this solves the problem.
Old Sep 16, 2008 | 10:14 AM
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
What type of phone are you using? I'm using a Nextel BB with puck and tail; can't get my contacts to download.
Old Sep 16, 2008 | 06:43 PM
baxterdown's Avatar
1972 280SE 4.5
I use an iPhone.
Old Sep 17, 2008 | 12:30 AM
mspaul's Avatar
I use blackberry
