E-Class (W211) 2003-2009
AC Issue
Old Sep 18, 2008 | 01:57 PM
jlw000's Avatar
2005 E500 Sport w/ AMG Package
AC Issue
I have an E500, 2005, 27K miles. Today i went 1 mile to lunch and on the way the air, which was on automatic, suddenly shut off...though the read out showed it was on. I hit the on/off switch and fan switch and it shows the fan speed, but still dead. I thought, o.k. maybe a fuse. I parked, went to my lunch meeting and came out expecting it to still be dead. But to my dismay, the AC worked immediately (I'd been happy knowing it was a fuse). So now I am going to have to go to the dealer and have it looked at I guess. Any experience out there that would point to a specific issue? Until today I have had no issue with AC. thanks
Old Sep 18, 2008 | 02:31 PM
Diesel Benz's Avatar
Sounds like the fan regulator although I thought that issue was a lot more rare on a W211 compared to older models.
Old Sep 18, 2008 | 03:41 PM
Barry45RPM's Avatar
2015 ML 350
I had the problem on my '04. Whenever the fans whent into Max Cool or highest speed due to demands for extra cooling, the fans would shut off, but would work as you say when restarting a little while later. It was a fan blower regulator located somewhere under the passenger side dash that was faulty. Back then, they had to replace it a couple of times. I believe the part has been updated, and after its replaced, you will have no more problems like that.
Old Sep 18, 2008 | 05:48 PM
jlw000's Avatar
Well this is exactly the same issue i had in my 530i and am not surprised to hear this. In that car the part is roughly in the same place and was about $100. After it was replaced it was fine. I suspected the same thing here but as this is my first MB was not sure the engineering was that similiar. thanks.
Old Sep 19, 2008 | 01:39 AM
I've had one replaced from a 5-series BMW, and one from an E-class MB (W210 though). I guess we can blame BMW.
Old Sep 19, 2008 | 01:53 AM
ehr1's Avatar
2002 E55 AMG, chevy truck,1984 190E(race car)
More than likely needs a a/c blower regulator. I replace 5 or so a month at work.
Old Sep 19, 2008 | 04:07 AM
Is that for W211 models? How would you estimate the likelihood of this failure between different MB models?
Old Sep 19, 2008 | 08:09 AM
deshelto's Avatar
2004 E55
I have the same problem, just haven't had time to take it in yet. Good to see the posts about what the problem could be. As a short term fix, whenever I see the a/c jump in to "Max Cool" mode, I manually adjust the blower speed down one notch. For some reason, that is enough to make it not shut off. Then when it cools down in the car I just hit the "Auto" button again. Let us know what happens when you take it in for repair!
Old Sep 19, 2008 | 10:12 AM
Barry45RPM's Avatar
2015 ML 350
My uneducated guess is that in Max or Defrost mode the fan motor is drawing max current which the regulatior can't handle. Interesting that in the '07's the A/C must be manually put into "Max" mode by pressing a button, while on earlier cars it happens due to cooling demands made by the thermostat.
Old Sep 19, 2008 | 10:55 PM
starbrite's Avatar
2004 E320
Per previous post by Konigstiger (resident genius) :
" A/C Blower not running :
P-B-83.25/76b Mar 07- Blower motor stops running.
May be caused by high blower output requested by the climate syatem and the blower regulator overload protection engaging unnecessarily.
The blower regulator will be replaced wit part # A230-821-64-51 (updated #, 1//08) if need be ".
Happenned to my car and regulator replacement solved the problem.
Old Sep 20, 2008 | 09:16 AM
TPAbnz's Avatar
2017 E300W
Same issue here . . . regulator replaced.
Old Oct 15, 2008 | 08:49 AM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
The Display on the dash for my AC Unit controls is so dim in the daylight that I can hardly read it........at night it's bright enough to read. I tried using the little knob on the overall Display to adjust the brightness and it doesn't make it bright enough to read. The brightness for the Radio display is o.k. Does anyone know what's wrong........is it the "light" unit the AC Display failing and can just the Display unit be replaced or does the entire AC control unit need replacing?
Old Oct 15, 2008 | 03:57 PM
konigstiger's Avatar
'71 Pinto
Check your email
Old Oct 16, 2008 | 07:35 PM
mcleantmw's Avatar
Check your email
Thanks for sending me the Service Campaign Bulletin but I don't think it applies to my situation. Even in regular daylight, not direct sun, the brightness on my Climate Control Display is so dim it's unreadable.......it's only readable at night. I researched on the MB Parts Catalog that there's a sensor unit under the hood near the windshield that operates the light dimmer and automatic rain detecting wiper blades. My suspicion is that this sensor unit is defective and is "locked" to be continually in the "night" mode. Why? Because when I tried my wiper blades today in the first setting, the rain sensing setting, they continually operated even when there was no rain. Does my diagonsis seem ontrack? The only other possiblity I can think of is that the Climate Control Display Unit itself is failing.
Old Oct 16, 2008 | 09:31 PM
'71 Pinto
Sent the DTB to give a better understanding as to what might cause difficulty in reading the LED display. Were the display and wipers malfunctioning before you had it in for service, could have had it checked then and circumvented a trip back to the dealer.
Old Oct 16, 2008 | 10:35 PM
mcleantmw's Avatar
No, they just started acting up after my recent service. I have to go back in a couple weeks for another visit to my MB Dealer once the Transmission ECU they ordered from Germany comes in. So, I'll have them check out the AC Display and Wipers auto sensing at that time.
Old Oct 18, 2008 | 11:47 AM
peterjthomps's Avatar
2004 E500 4MATIC
Had the same issue.....
I experienced the same issue with my Temp controls. It was related to the sensor located near rear view mirror. I had a new windshield put in and the sensor was not completetly connected. I would check to make sure it is completely secure. All I did was disconnect and reconnect everything and since then no issues. There are other references in this forum related to this problen, and one that has instruction on removing the sensor control near the mirror.
Old Oct 18, 2008 | 11:04 PM
mcleantmw's Avatar
Thanks for this input.......glad you mentioned about the sensor being located at the top of the inside of the windshield. I'll look at it in the morning to see if the electrical connectors are firmly inserted or not. The rain sensing wipers definitely do not work properly since they just keep operating in an intermitent mode in dry weather and the Temp Control display just stays in the night mode and unreadable during the day. Glad to know my theory about this sensor being the issue was ontrack!
Old Oct 19, 2008 | 06:19 PM
jlw000's Avatar
Where is that little "knob"? I cannot seem to find one that does what you describe.
BTW. I did finally get this AC problem fixed this week. They replaced both the regulator and the blower...under warranty.
Old Oct 19, 2008 | 08:25 PM
Barry45RPM's Avatar
2015 ML 350
The knob is lower left at the cluster. The same knob you press in to reset your trip info and other things. You can press it in and also rotate it clockwise/counterclockwise.
Old Oct 19, 2008 | 10:00 PM
jlw000's Avatar
i thought that had to be it and it tried it and did not see any difference, but now that it is confirmed, I will pay closer attention. thx.
