E-Class (W211) 2003-2009
Active Headlights
Old Sep 19, 2008 | 12:02 AM
RyRoRyan's Avatar
05' E320 (W211)
Active Headlights
Can they be disabled somehow? You know so that at all times, they just point straight ahead exactly where I have aimed them and never move again. Why...do I want to do this you ask, well I might have a problem with one of the headlights and would rather disable at the current time than spend the 1500 bucks for the price of the light alone.
Old Sep 19, 2008 | 01:35 AM
Diesel Benz's Avatar
You must be referring to the turning headlights, not the cornering fog lights. The early active headlights seem to have some sort of an issue with the horizontal control motor. I've seen lately a huge number of owners reporting about the motor failure. Perhaps you should get some good will compensation for the fix.
The feature cannot be switched off. I doubt it would work if you coded the car for basic xenons. I guess you currently also have a malfunction indicated at the cluster.
I've encouraged owners to have a look at the lamp design, if the horizontal control motor could be changed. Officially the whole lamp unit is one spare part and parts of it cannot be serviced. But the vertical motor should be an MB spare part (for another model) and owners who have had issues with that, have successfully changed this motor only.
Old Sep 19, 2008 | 06:07 PM
konigstiger's Avatar
'71 Pinto
DTB P-B-82.10/626 JUN08 Curve illumination nonfunctional up to VIN A564853 and X161341 the actuator lines for the motor, sensor and/or bi-xenon bulb of the reflector module can chafe on the metallic leaf spring during swivel operations and cause a short circuit. To resolve, repair film will be applied to both headlamps.
Out of warranty
You can purchase repair film part #A2118260124 for $20 and follow install instructions within DTB however, if there are any fault codes stored they will have to cleared by dealer through SDS.
Old Sep 19, 2008 | 10:43 PM
RyRoRyan's Avatar
05' E320 (W211)
YOU ARE THE MAN!!!!! Where can I get a copy of the DTB?
Old Sep 20, 2008 | 12:01 AM
'71 Pinto
PM your email address
Old Sep 20, 2008 | 02:42 AM
Out of warranty
The first time I see the "technical explanation" for the issue. Too bad it exists but not as bad after there is a known way to solve it.
Old Jul 21, 2010 | 03:20 PM
dpavid's Avatar
2005 AMG E55
Out of warranty
Sorry. What is DTB?
Old Jul 21, 2010 | 04:01 PM
'71 Pinto
Originally Posted by dpavid
Sorry. What is DTB?
Dealer Technical Bulletin (service bulletin) normally not covered out of under warranty unless modification is documented to correct a known defect (production or otherwise) in which case one can argue for a goodwill repair out of warranty.
Old Jul 21, 2010 | 05:59 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
So when I turn on my headlights against a perpendicular, flat white wall, I clearly see them aim up & down (self-level), and I think I MAY see them quickly dart side to side, but I'm not sure. The motion is VERY quick, and it doesn't seem to go very far. I tried pulling the car further away from the wall (increasing the distance of the pivot which would hopefully exaggerate the movement), but there still doesn't seem to be much of a change.
BTW.. I had the car scanned in May and didn't see any headlight fault codes. Also, does the cornering occur with the highbeams on as well? When switching from low>>high, I definitely see the lights aim up.
I can scan the car again in a few weeks, which code should I be looking for if I can't manually verify cornering?
Old Jul 21, 2010 | 06:08 PM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
DubVBenz .. when I'm driving if I return the car to straight from a turn abruptly, you can see the headlights "lag" a bit.
There is a euro style "round about" by my house. When I come out of it, if I do it abruptly and watch the headlights, you can see them lag a bit.
Old Aug 1, 2010 | 03:56 PM
DubVBenz's Avatar
I've started to really pay attention and notice the movement. I'm in the middle of an urban area, so my headlights are often not the single source of light. I'm looking forward to driving the car at night in some more rural areas to check out this effect.
Old Aug 1, 2010 | 06:14 PM
Vik888's Avatar
I'm in a fairly well lit area and its still visible .. just make abrupt turns and the headlights lag because they weren't meant to deal with such abrupt movements .. just be safe doing it because it requires you to look elsewhere than where you should be looking during a turn.
