E-Class (W211) 2003-2009
320, 350, 550 4MATIC
Old Sep 27, 2008 | 01:15 AM
konigstiger's Avatar
'71 Pinto
Arrow 320, 350, 550 4MATIC
211.082/087/282/287 (320 4matic, 320 4matic wagon, 350 4matic, 350 4matic wagon)
Metallic knocking/rattling noise from the front axle area when driving on rough and/or uneven road surfaces when the wheel rebounds
Mention DTB P-B-32.25/68 SEPT08, the dealer will replace the front shock absorbers with revised parts (Left A2113237900, right A2113238000). Revised shock absorbers planned to enter series production on 10/1/08.
211.090 (550 4matic)
Vibration and/or chatter from powertrain while making small radius turns at low speeds
Mention DTB P-B-28.50/10 JUL08 Caused by changes to the friction coefficient of the clutches in the center differential. Dealer will replace the transfer case (A2112801000).
Old Sep 27, 2008 | 03:23 PM
BenzBee's Avatar
Mine: 2008 E350 4Matic --- His: 2014 E 550 4Matic
Thank you for posting this information. Funny - I had the same problem in July within weeks of purchasing the car. The service advisor before looking at the car was saying it was a rattle in the dash! They fixed it for the time being but I will show this to the service advisor when I take the car in for service.
Old Sep 14, 2010 | 09:38 AM
VladW211's Avatar
2004 E320 4matic Wagon - 55k miles
Hi,
Do you know if this is the case with an 04' E320 4Matic Wagon as well? Is there a mielage limitaiton to the recall (mine has 51k)?
I took my car in for this problem and they did not mention nor offer this bulletin repair.
Same exact symptoms, primarily on speed bumps and when rebounding (on mine it appears to be on the drivers side only).
Thanks a bunch!
Old Sep 14, 2010 | 10:23 AM
lkchris's Avatar
'10 CL550, '12 GL550
DTB are NOT recalls, which are only for safety and emissions.
DTB are performed free while car is under warranty ... afterwards you pay.
Old Sep 16, 2010 | 10:41 AM
Kingpapa's Avatar
w211
Q: Would they also replace them if the car is out of warranty?
Old Sep 16, 2010 | 10:59 AM
lkchris's Avatar
If you pay them.
Your car must not have the problem or someone would have complained to a dealer by now.
DTB are for customer complaints--no complaint/nothing needed.
Old Sep 16, 2010 | 09:07 PM
benz188's Avatar
Benz e class
Smile
Thank You,
mercedes benz, benz
