E-Class (W211) 2003-2009
Brake issue ( 1 malfunction )
Old Sep 29, 2008 | 07:55 PM
deadalous's Avatar
w211 Mercedes E230 2003
Hi there,
i have a Mercedes 2003 E320.
My cluster is showing 1 malfunction, when i open it it says:
"Brakes
Brake service visit workshop."
i changed the brakes but the alarm is still there.
what could be the problem?
thanks in advance
Old Sep 30, 2008 | 11:16 AM
Clinton Horn's Avatar
2003 E320
It is hard to judge the knowledge members have as people come and go. The pads have a sensor embedded in them. It is a coated wire loop that shorts out when it contacts the rotor. They are pretty cheap to buy and very easy to damage when installing. The vehicle has no way to judge pad wear without them. Unless you have other issues (SBC or brake fluid) I would start there. I installed new ones and still managed to damage one during the process. Had to take the tire back off and replace it.
Old Sep 30, 2008 | 11:44 AM
MB211's Avatar
2005 E500, 2011 ML350
Does it show:
(O) Brake Wear, visit workshop
or
BRAKE! Visit Workshop
The latter would be a malfunction with the brake system (stop lamp, SBC battery, SBC pump, brake fluid......) and needs the codes to be pulled....
Old Sep 30, 2008 | 12:47 PM
deadalous's Avatar
it says:
i will check what you told me tomorrow thanks all
Old Sep 30, 2008 | 04:26 PM
willscam's Avatar
Black 2003 E320, 2001 BMW M Roadster
Check out sticky thread #7 at the top of the forum. It should solve your problem.
