E500 Interior Mood Lights
a) ambient lighting we all have and can turn up/down/off
b) reading lights and "big" front and back lights; on/off via switches
c) a little yellow "always on" light underneath the mirror.
That's on my standard E320 (Canadian standard, that is). No extras.
Michael
Ed
My under mirror lights illuminate when I unlock at night, along with the interior lights. Try holding your hand under the light and you'll notice the ground is illuminated. I only get the exterior front and rear lights on when the light switch is in "Auto". I believe on prior models, you got the exterior "surround lighting" (used to be "locator lighting") -when activated-even with the light switch off.
Can you run thru the settings and the actual steps to get the lights on when you unlock the door. Maybe something is wrong with mine.
Ed
I have been checking this in the garage or at night, so I'm not sure if in overhead sun any of these lights come on. I seem to recall (maybe on my '01 C rather than this car) that the interior lights only activate with doors when the sun sensor tells them to, but I haven't checked that here specifically.
Let me know if you need any other setting info. I added all the other options I have (and don't have!) to my signature but I doubt any affect this.
Thanks, as usual the answer was very simple. For some reason, I had the interior overhead light turned off. Not only were the lights under the mirrors not coming on..neither were the interior lights.:p Some how I did not notice.
When the answer is simple it does take a step by step direction to see the obvious.
Thanks again.
Ed
in the 'settings' sectiopn....the same place where you set automatic door locks, 'delayed headlamp OFF', delayed internal lights fadeout on locking etc.
its in the multifunction display, under I think ;lighting' and then 'approach lights' or 'surround lights'..its an odd title.
I had all the menu items correct...just lights turned off.
Ed
