E-Class (W211) 2003-2009
Battery
Old Oct 17, 2008 | 10:50 AM
eagle67's Avatar
Battery
I have a red battery light malfunction on a 2003 E-500...Where is the best place to buy a battery?
Old Oct 17, 2008 | 10:59 AM
MB211's Avatar
2005 E500, 2011 ML350
from the dealer.....
Make sure you replace the correct battery, typically a red light is the aux battery located under the hood.
Old Oct 17, 2008 | 11:14 AM
jwex2's Avatar
1999 clk cabriolet
battery
call roadside assistance. Pay for the part, free installation at your location.
Old Oct 17, 2008 | 11:34 AM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
+1...going to the dealer will get you their "bend over w/o lube" labor rate special...good luck.
Old Oct 17, 2008 | 11:59 AM
eagle67's Avatar
Is there a trick to getting the battery cover off, I'm having trouble
Old Oct 17, 2008 | 12:45 PM
MB211's Avatar
This trick works pretty well, certified MB tech does it for you......
I do not know if they do the aux battery though, sign and drive is supposed to be for jump start / battery replacement when car is not starting.
Also, it may not be a bad idea to have the car looked at. You make have additional issues. (i.e battery control module fault). You may even want to check if the campaign for control module flash applies to your vehicle and was performed.
Old Oct 17, 2008 | 02:24 PM
eagle67's Avatar
Thanks MB211
It was the aux battery and the trick to getting the top of havc was just "snapping:" the cover from the side back.
